Computer keeps shutting down for no reason. anytime you start up it has to go through several different screens. which takes about 10-15 minutes. computer is an Acer Aspire 5100.
    Problem Solver:
  • 17 Answers
You need to let us know what screens keep coming up. The only screens SHOULD be the initial POST screen (which is usually black with info about your system), then the windows start up screen. Then your desktop should show. If there are numerous screens popping up after this - are they browser screens (ie. Internet Explorer or Firefox)? If so, you're probably infested with spyware.
BTW - some systems hide the POST screen with their own logo, like Compaq.
Send more info, and it will help in fixing this.
Posted on Apr 15, 2008
Car shuts down for no reason while driving is there a solution?
Solenoid holding the bendix drive in mesh have starter checked out
Feb 22, 2015 | 2006 Buick Lucerne
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
Medion md1768 has been reformatted, recovered several times, but it continues to power down and restart at anytime. There doesn't seem to be any rhyme nor reason. I believed it to be infected so had the...
I think you need to shut off reboot on error
Here is some info on this
then it should show you the error screen instead of just rebooting
could be some hardware problem
Sep 02, 2010 | Medion MD-1768 PC Desktop
The Startup repair program is running and wont stop
A complete scan can take several hours to complete. If you want to shut it all down unplug it and remove the battery. Leave the battery out for at least 10 minutes, and until it cools down.
Nov 04, 2009 | Computers & Internet
Engine dies for no apparent reason after several hours running
Sonds like a sensor putting out an error code to shut it down ( like a fatal error code) Prolonged vibrations and heat can make cam sensors, maf, o2 senosr do craz ythings which will actuate a govener and stall your car...could also be you fuel pump causually telling you that "hey im bout to die".I dealership can run a stress test (if you will) to check the longivity of the pump...
Good luck hope this helps :)
May 19, 2009 | 1996 Nissan Quest
3 month old Sony Vaio notebook keeps turning off by itself, won't even last more then a couple seconds to a couple minutes, tried system restore and defragmenting, and disk cleaning...still nothing!! could...
Try on the BIOS/System Setup and check if its turning off there as well. To entere there, start your computer up, and when you see the Vaio logo press [Delete] several times. You will see a blue screen or black with information of your computer, leave it there for as long as it takes to shut down, if it doesn't then please let us know.
May 04, 2009 | Sony VAIO PCG-K35 Notebook
Acer aspire one crashed after installing xp service pack 3
Your installed software version, to include windows (your operating system) is corrupted in some form. It may be several different reasons, but in most cases it is caused by deleted files or a piece of hardware which is about to fail, most times, the hard drive. If you've only had it for a few months, you should absolutely get it in for repair as soon as you can!
Jan 14, 2009 | Acer Aspire 5315 Notebook
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
