Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Convergence I replaced ic's but red is still a problem but it fixxed the blue. vertical red line is shorter than green and not quite straight but close and vertical will not adjust up or down at all even after replacing the chips. Any location #'s of any resitors that will fix this? also none seem to be burnt but that doesn't always mean anything.
  • phillipshate Apr 30, 2008
    up and down red convergencence does not work
  • Philips Master
  • 8,617 Answers
There will be around 12 resistors all identical 6.8ohm that will sometimes go open if they dont have color bands they will be marked as 6R8 1WJ which means 6.8ohm 1 watt 5%
Posted on May 07, 2008
The tv has red images, I cannot get the red convergence line vertically to straighten, it is squiggly, the horizontal is straight, and the blue and green lines are both okay
the 43h71 has a pair of convergence ics that commonly go bad and cause this problem. replace original stk392-110 with stk392-120. the upgrades have a collector rated at 4 amps vs the 110's 3 amps and should be more reliable.
also know that they hyperboard in this set can cause squiggly lines throughout but will not affect the convergence.
Jul 06, 2010 | Toshiba 43H71 43" Rear Projection...
The vertical green convergence adjustment is broken
Either your convergence ic's are bad or the convergence digital module ( if your model has one ) . I would have it looked at by a service company.
Jan 16, 2010 | Hitachi Televison & Video
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Mitsubishi VS50805 Serial # 102718 No red in picture
Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
How to adjust the green convergence?
Hi, If the green crosshatch lines are bent or curved then you have an IC failure, Green is the reference so it can`t be adjusted with your remote, the correct procedure is to move the red and blue on top of the green to make the crosshatch white, As I said if the green horizontal or vertical lines are not perfectly straight then it needs repair not adjustment, BMW Rider
Dec 12, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
