Question about HP LaserJet 1015 Printer
Network print install - HP LaserJet 1015 Printer
  • Jacklift Apr 28, 2008
    I have installed the MX 700 to my xp desk top but am having trouble connecting my Vista laptop to the printer on a wireless network. Does anyone know how to do this?
Dear Sir,
my Printer is hp 1015 they are installed in xp user but add the vista user not printing in vista user
plz any soluation for him
Posted on Sep 29, 2008
  • 813 Answers
Won't print to network printer
do you print it to the computer were the printer were you want to print or to another computer were the printer is installed to other computer and you trying to print it by search it to the network to print..if it is the same OS that you are using there is no problem on it..but if it is different OS like you likr to print it to the pc if it is win 7 but the printer is connected to a pc were win xp is the OS he/she using you must install it again..go to youtube and search..how to print to other pc by network.
Dec 08, 2011 | Brother MFC-8480DN All-In-One Laser...
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Tip
INSTALLING A NETWORK PRINTER These instructions generally apply to all network...
These instructions generally apply to all network printers with built-in network cards (print servers) such as HP Laserjet printers, IBM Infoprint laser printers etc.
This example is for a network HP Laserjet printer.
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer’s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
on Dec 06, 2009 | Computers & Internet
Will not print Have installed the software but cannot print. I notice that an icon (Two blue screens) says network cable unplugged.is this relevant to the printer problem
if ur not printing on the network printer or shared printed of ur network, yes, but if so, of course you cant print. try this:
network: "ON" the network switch/router. check the network cable and other until that the unplug msg
disappear.
local:(PORT ON LTP/USB and IS NOT a TCP/IP PORT): 1. look at ur printer, it should be that the green led is ON ang no blink. RED led also denotes that empty ink and needs a replacement.
2. the installation cd must be compatible to ur OS
Mar 31, 2010 | HP DeskJet 5550 InkJet Printer
How do i solve the printing ID problem of c5200
re install your printer...
install it in one of your network...
Feb 03, 2010 | OKI C5200n Laser Printer
I have a netgear wireless network. I am trying to
you can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
Sep 09, 2009 | Linksys Wireless-G WPS54G Print Server
How to install the lexmark E120 network printer
to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
Dec 22, 2008 | Lexmark E120n Laser Printer
Need set up Lexmark C534n to our office network.
Does the printer have an IP already assigned to it?
Print out a network settings page:
Printing a network setup page
If the printer is attached to a network, print a network setup page to verify the network connection. This page also
provides important information that aids network printing configuration.
1 Make sure the printer is on and Ready appears.
2 From the control panel, press .
3 Press until Reports appears, and then press .
4 Press until Network Setup Page appears, and then press .
After the network setup page prints, Ready appears.
Note: If an optional internal print server is installed, Print Network <x> Setup Page appears.
5 Check the first section on the network setup page, and confirm that Status is “Connected.”
If Status is “Not Connected,” the LAN drop may not be active, or the network cable may be malfunctioning.
If that is an IP not on your network, then you need to change that IP to an unassigned IP that is on your network.
You can do that by typing in the IP of the printer into a web browser (example: Http://ipaddress)
Then you should be able to modify the IP address from here.
Once the printer is on your network, make sure you have drivers for it installed and then just map any worksttaion to it.
Dec 11, 2008 | Lexmark Office Equipment & Supplies
We buy canon copier ir3035 with all acces,every thing is don but we cant install properly pdl kit,because its not accepet printing from networking or we tray to print through usb port as will after install...
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Jul 24, 2008 | Canon Office Equipment & Supplies
Unable to send a print job to the device.
i know what your problem is phone 07764303923
Oct 06, 2007 | Canon imageRUNNER 5570 Copier
HP LaserJet 1015 Printer Logo
116 people viewed this question
Ben Johnson
