MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion..... make sure your usb 2.0 driver is installed..Syncing to wmplayer puts music in the mtp music folder. change usb modes again and use the explorer to see the sansa msc lets you sync any Q/A IM or email me @ [email protected]
SOURCE: Double Songs
Your device has 2 modes, if you transfer music in one mode, it is not visible in the other.
You need to select 1 mode Settings>Mode or USB Mode>MSC or MTP.
Connect the device to your PC. Open the device under My Computer and delete all the music.
Change the mode back to the other one and keep this as your permanent setting.
You will not see duplicates anymore.
Best of Luck.
SOURCE: sansa e260
go to www.sandisk.com, and then just keep following the links for mp3 players, support; or go to:
https://www.customernation.com/pls/ps/ps.ps_main?p_host=304&p_supplier=5096&p_parm=PSHPP
they did redesign the website recently
SOURCE: How do i reformat my Sansa e260 mp3 player?
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
