Question about Dell Dimension 3000 PC Desktop
Hard drive i made a dvd copy had 28 gigs of memory now i only have7.5gigs
  • 667 Answers
Do you mean that before you made the copy your hard drive had 28GB of free space and after you only had 7.5GB free space? How did you make the copy? Most likely just temp files that can be deleted. To be sure , tell me how you made the copy ans I'll let you know what's going on. Thanks.
Posted on Apr 15, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Apr 15, 2008
    Please explain a little further exactly what it is that you did. Thanks.
    Problem Solver:
  • 17 Answers
Could you be more specific? Do you mean you had 28 gigs on your hard drive used up, but the backup only copied 7.5 gigs? The message you left is pretty sparse.
Konica runs out of memory
Print and copy jobs are ripped to your hard drive on this machine. Your hard drive may be failing. You can try a logical format through service mode.
Apr 10, 2014 | Konica Minolta bizhub Office Equipment &...
I have just bought a PNY flash drive with 32GB of memory. I want to store my iPhoto library into it and then transfer it to my MacBook Air. How do I simply store the pics on the flash drive - not one by...
I would Assume that all your Pictrues are in 1 folder? If they are just copy and paste folder into your 32 Gig Stick And then use Gig stick and Copy Folder out to your Mac air..
Just check to make sure folder size is Under 31 gig's in size..
Hope this helps. BCB...
Oct 21, 2013 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Ms-6540 won't post with 2 gig memory
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 12, 2012 | Computers & Internet
Hello sir i have kingston 32gb Ccore ccm3110 pendrive it can copy any thing but after copying to my pc the first video file can play ony 14.2 min and others will not open at all solve my problem please
May be your pendrive has corrupted the files or may be your pendrive has some viruses.
I suggest u not to use so much memory on pendrives as sometime pendrive automatically corrupt your data.Use small memory of pendrive.If u want to use big memory it's better u use hard drives
Jan 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
I need help finding drivers for my Intel 865gv P4
Which website are you getting your drivers from? Gigabyte has the drivers for that chipset. Are you using a DVD copy program to bring your files to the disk? Do you have enough Disk Space to copy them on to your Hard Disk in a folder you create? This is sometimes the best way to retrieve your files and put them on a DVD.
Nov 05, 2009 | Computers & Internet
Windows XP background loads but no icons/task manager/start menu
well copying the files may be the problem! for instance you need a recovery cd or dvd if you made one and use that to reinstall ur OS like the day you bought it!
try making or getting a windows installer disc then either install ur original OS like home or professinal or use the repair feature that shoud install all the drivers and .dll file you need
Aug 27, 2009 | Microsoft Windows XP Home Edition
DVD copy and Paste aborts Copying PDF files from DVD on laptop with windows Vista. 1800 + files, about 2.72 gigs. Using copy and paste. It stops responding with about 2 min to go, copying about 1/2 the...
Hi, i want to suggest you to never use "COPY and PASTE" function for copying files to dvd,you must use nero8 or any previous version for burning the files in large quantity,
and if you are not able to arrange any of such softwares, you may try copying the files into a folder, and than paste folder in the DVD,and close all applications while copying,
tell me the results plz
Aug 01, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
I have just purchased a pioneer dvr-lx60d dvd recorder with a 250 gig hard drive built in . i would like to know how to back up my dvd collection on to the hard drive .?? can you help. the player wont let...
i have played a dvd movie in my laptop computer(Toshiba dvd player) it has played
but when i try to ply it in my desktop computer(LG dvd player) the disk is not opening do you have a soft ware or suggestion to solve this problem
Jul 13, 2008 | Pioneer Televison & Video
Dell Dimension 3000 PC Desktop Logo
53 people viewed this question
Alun Cox
