Question about Kenmore Oasis HE 27062 Top Load Washer
Remove computer? any help on removing the computer? I am trying to remove the interface unit and don't really see how it comes out. Do you have to take all the little nuts loose and come out the front of the control panel? thanks for any advise. liketotinker
  • 246 Answers
On an oasis waher, ther should be 3 phillips screws on the back side of the console. Once they are all unscrewed, the console should tilt forward. To get the board out, remove the 1/4 inch screw towards the bottom on the front. There are two black plastic tabs that hold it in on the top.
Posted on Jun 15, 2008
Mhwe300vw11 error code f 70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa
Oct 09, 2011 | Maytag MHWE300VW Washer
Kenmore elite 5t washer with code f71
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2010 | Kenmore Elite 45986 Front Load Washer
How is error f28 and f171
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Feb 02, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
E 70 error message
Sep 29, 2009 | Kenmore Elite 45986 Front Load Washer
TROUBLESHOOTING KENMORE ELITE HE3T FRONTLOAD WASHER WITH THE ERROR CODE F70
Sep 26, 2009 | Kenmore Washing Machines
What is "F" code 70?
Jun 30, 2009 | Kenmore Washing Machines
Washer triggers an F70 code stops wash cycle.
May 10, 2009 | Kenmore Washing Machines
My AUX dosen't work right every time i connect it to the ipod
May 06, 2009 | GPX HM3817DT Shelf System
Kenmore HE5t washer - F70 error
Dec 31, 2008 | Washing Machines
Error code F71
Jul 07, 2008 | Washing Machines
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
