USB problem when the input device is inserted, it says USB device is not recognise. but it detact mouse. how can isolve this problem
    Master:
  • 351 Answers
Dear imyan ,
this problem is related to your operating system, here i suggest you please update the USB driver in your system or you can download it from internet.
Regards
Posted on Apr 16, 2008
My mouse wont get recognized
Have you tried to use the mouse in another computer to determine that the mouse if fully working. There are many reasons why it could be non-recognised. Has it ever worked on your system? Is it new and just a faulty mouse. It may be you could just take it back to the shop for a replacement one. Do other devices work in the same USB port. Some times my computer just stops recognising my USB keyboard yet it has been working for months. I found that it seems to be the USB port where the problem is. So not I just switch my mouse and Keyboard usb connectors around and it starts to recognise both again. I can not figure out why it stops. As another device is recognised suggesting the port is not faulty.
Nov 01, 2013 | Computers & Internet
Usb mouse not recognised its a asda hm5058
freedownload optical mouse model no: hm5058 i cant do it
Jun 01, 2011 | Computers & Internet
Mini optical mouse, rating 5V, 100mA the mouse works sometime fine and sometime it is not recognised.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 08, 2011 | Computers & Internet
New not working
Refer to the manual, in some cases you have to install the drivers that came with the mouse, first before it will be recognised. Use your old mouse for this part.
Secondly make sure that the batteries are inserted to the correct polarity, and that the USB receiver is connected to USB port at rear of Computer.
Try using another USB port.
Please rate my expertise.
Thanks
Nov 01, 2010 | Toshiba Wireless Mouse PA3205U-1ETC
My wired mouse is not recognised on my laptop
I assume this is a USB mouse and it should work.
Attach the mouse and check your device manager that can be accessed by doing the following:
Find the icon for My Computer (XP) or Computer (Vista, Win 7).
Right click on it and then choose the hardware tab.
When that tab opens, click on device manager.
Check the mouse item to see if your mouse is recognized. It may have an exclamation mark on it. If so, right click on it and delete it.
Check the USB devices at the end of the list to make sure there are no exclamation marks on any. If there are, delete them.
Restart the computer to see if the devices are found. This should work. The only problem you could have is if the mouse itself is bad or if your motherboard is having a problem.
Jan 04, 2010 | Microsoft Wireless Mobile Mouse 3000
LG GSA E 40 L External dvd writer not recognised
you may be having conflicts with usb devices. try temporarily removing all unnecessary devices from the usb ports. unplug and then plug the drive back in. you could try another port. if all ports are in use, then unplug another device, like the mouse and plug in to that port, then plug the mouse into the writers port. i had a similar problem with a wireless usb lan that stopped another device from being recognised. when i removed the lan and replugged the unrecognised device, windows recognised it. i obviously had to use the wireless lan, so i swapped that with the mouse and it worked.
Jul 19, 2009 | LG GSA-E40L Burner
Toshiba Wireless Laser Mouse
the usb has to be inserted to use the mouse
once you remove it you've removed the mouse
don't forget to rate
Feb 02, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Usb not recognised
the connector of you usb port of your unit kinston is need to re_soldering by using a soldering iron.or need to re-heat by hot-air unit.
kira_ryuk@yahoo.com
Jan 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb port not recognising devices and mouse pad not responding
hello there. It sounds as if your motherboard (bios) is not configured correctly, or your windows drivers somehow got corrupted. check in your MoBo's manual to see how to access it's bios options. and make sure that your onboard usb options are enabled.
Nov 23, 2008 | Microsoft Computers & Internet
Usb ports
u can upgrade the bios in your pc by downloading the bios from the manufacturers site ,i thinkthat shld get it to work with the usb device
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
