Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
Display screen what does H mean ?
  • 1 more comment
  • Jaye
    Jaye Sep 10, 2008
    Thanx heaps for ur help :)
  • ajay pramod May 11, 2010
    more details..!!!
    pls post more details..
This is like the "BAND" or network of your provider. Instead of "H", some network provider will show up 3G, some will give you 2.5G or 2G.
Posted on May 18, 2008
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
What does OSD locked mean?
OSD means: On Screen Display, you have the choice to see or not to see the display on the screen.
Mar 15, 2012 | AOC 2436VWH LCD Monitor
White screen 6500 slide I need help plz I've
Display can be Lcd,Flex connector,board connector,display IC etc.
If you already try at least 2-3 lcd, take another step of replacing flex connector 2-3 also, to make sure that the item you bought has no defect.
If this 2 parts didn't make it, check the board display terminal if its clean and corrosion free. resoldering each terminal may be helpful enough.
last option is replacing the display IC, it will serves as a fuse of it, a clystal square type that generate current to be able to display on screen.
Jun 28, 2011 | Nokia Lands Phones
No display on screen but phone works
Hi, you mean work, that after you ON it still can ON but your screen don't display anything( black and no light)
it mean you need to change new screen or ribbon
If it just ribbon problem, it is okay. But if change new screen it need more money to pay.
May 28, 2011 | Panasonic KXTGA560S 58 GHz Phone
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Only white screen is displaying on my sony ericsson k550im mobile pls help me
Hi,when a phone displays,white screen,it means that the screen of the phone is bad,that's why the screen is not displaying.
Replace the screen and the phone will be normal again.
Take care.
Sep 26, 2010 | Sony Ericsson K550i Cellular Phone
No display
Hi,no display is cause by the screen of the phone. You will need to replace the screen of the phone for it to be able to display again.
If the phone doesn't works even when the screen doesn't display,That means it's a software problem.
Sep 23, 2010 | Nokia N70 Cellular Phone
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Sep 12, 2009 | ViewSonic VP201b 20.1" LCD Monitor
Sony pcg-5a1l display problem
what do you mean display problem ? the red shows as pink ? the screen is black ? the screen is dimmed ? the screen produses smoke ? images are distorted ? screen is crashed ? - i can guess 100 things that mean "display problem" :)
if its not a software issue then it should be vga or tft... and are very expensive to fix... see for a new laptop...
Sep 03, 2009 | Sony Computers & Internet
Oven will not come on. Display screen flashes F2.
The error code means that bad relay on control board.
It could also mean that sensor is not making proper
connection with the board.
Sep 01, 2009 | GE Ovens
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
