Question about Hyundai ImageQuest L17T 17" LCD Monitor
L17T No power... nothing!!! Tried new power cords and everything.
  • 1 more comment
  • Nissen May 08, 2008
    How can I open the cover. Do you have a description
  • Nissen May 13, 2008
    I have a. l17t monitor, there are going in black with no power. I think a fuse maybe are gone, but I can´t open the monitor. I have tried to take the silvercover off, but I can´t get i free over the foot. It´s free on the three other sides. How can I get it free on the side four.
    Thanks
    Niels Peter Nissen
    Denmark
  • Anonymous Feb 16, 2009
    MODEL L17T POWER IMAGE
    Scholar:
  • 176 Answers
If you can open the cover of your monitor try to locate the fuse maybe the fuse is busted replace it.
if the fuse is blown or busted again there is short circuit in your power supply maybe the diode or the power transistor is shorted you need this to bring to the shop for services
Posted on Apr 16, 2008
  • jemuel osorio
    jemuel osorio May 12, 2008
    next time you asked a question make it clear to so that we answer you clear also.
ImageQuest ImageQuest L17T 17" LCD Monitor: unit does not power up...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | Hyundai ImageQuest L17T 17" LCD Monitor
Canon Pixma Mp810 won't turn on, any suggestions
I had the same problem. Everything was working fine one day, but when I tried to switch it on the next day, nothing! The status light came on green briefly but then turned off. I thought the power module might be blown so I ordered a new one, that changed nothing, my printer was still completely dead, showing no sign of working at all.
I dismantled it to inspect every component for signs of failure, everything looked like new. Having read that the print heads can fail (dry out then blow) on canon printers, I tried starting the printer without the printhead and hey presto, it turned on and went through it's startup cycle. After making whirring sounds for a while a message popped up telling me that there was no printhead installed. As soon as I reinserted the printhead the printer turned off and wouldn't turn on again, even if I removed the printhead again (and unplugged/waited etc). I had to unplug and then re-plug a connector on the printer's motherboard to get back to the stage when the printer would turn on (without the printhead).
I have inspected the printhead with high powered magnification and found nothing unusual - a new printhead is about $100! My final conclusion is that there is nothing actually "wrong" with the printer but rather that it is a case of programmed obsolescence. My printer is about 5 years old (like new) and in the service manual that is the prescribed lifetime for the printer, so it's designed to simple stop working after that time.
PS. I did do the ink well reset procedure, didn't help.
Mar 19, 2010 | Canon PIXMA MP810 All-In-One InkJet...
My Wii will not power on
Have you tried using someone else's Wii power cord? The power outage may have fried the power cord. If you try a new power cord and it still doesn't work, then it seems like the only thing you are able to do is to send it in for repairs. When you try and use a different power cord, borrow a friend's if possible instead of buying a new one, just in case.
May 01, 2009 | Nintendo Wii Console
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Won't power on
Have you checked if the outlet has power? If so That is not good because that means that the Power supply is shot, or some other component is shot. If it has no power reset the circuit breaker.
All The Best,
RCF
May 27, 2008 | Computers & Internet
No power or lights on my inspiron 2650 laptop
First you need to test your adapter first not the power cord.Check that your adapter can give out according to the adapter spec..maybe 16-19ou V.If it does and still you laptop don't turn on then you have motherboard problem.
takecare.
May 05, 2008 | Dell Inspiron 2650 Notebook
Nintendo DS wont charge at all
Replace the battery. You can purchase a new one at nintendo.com.
Mar 11, 2008 | Nintendo DS Console
Regular xbox
it might be the wiring in the cord that hooks the Xbox(R) into the outlet, or it could be the outlet, hope this helps
Nov 03, 2007 | Microsoft Xbox Console
Hyundai ImageQuest L17T 17" LCD Monitor Logo
303 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
