Question about ViewSonic VX922 19" Monitor Flat Panel
No Power, But I can't open the plastic case
I have a "dead" VX922, so I decided to take the 4 screws out of the back and take the base off. But guess what? I cannot figure out how to take the plastic back cover off. It is still secured with some kind of hidden plastic. Anyone know how to pry this monitor apart once all the screws and base are off?
Andrew Gray
  • 88 Answers
Viewsonic Vx922 is sight tuf to open the rear door
Take and sharp blade
one side there is small gap to insert it
and then just twist and move front and round the monitor
all clips inside will unlock after that it will open
Thank U
Posted on Apr 16, 2008
  • 180 Answers
Hi Andrew,
Try to study of how to open it from this web site .
www.lcdrepair.us will be very helpfull to you.
Have a try
TIA
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
Jun 13, 2015 | JBL OnBeat Rumble Wireless Speaker Dock...
How do I get the back off of my Viewsonic VX922 monitor?
take out the 6 screws that hold the stand start from the bottom and spred the two covers apart at the split
Jan 30, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 monitor no power
I had the same problem with my VX924. The two 470uFx25V was blown, and the output diode was in short circuit. I also noticed that the 33R SMD resistor (to pin 6 of SMD IC) was opened. After replaced these parts, the monitor works great.
Aug 31, 2009 | ViewSonic VX922 19" Monitor Flat Panel
When power is applied to the lcd monitor vx922, then green light ON and the screen shows dispay for one second and then screen shows dark screen permanently
If obtaining the capacitors is a problem you can purchase a replacement power supply from the Viewsonic store. I just performed the repair on my VX922 and it works Like a champ. The replacement power supply is Part Number B-00003993 PSU - Supply (ADP.INV, FSP043-2P101 90"264V GP) according to the invoice. The total cost shipped was about $35 when I ordered it on AUG 5, 2009. It was quite easy to do and took 30 minutes. The monitor is working like a champ. The capacitors where in fact swollen but that led me to believe that other components may be suspect hence the decission to go with the entire supply based on the minimal cost and lack of availability of capacitors. Tools needed were phillips screw driver set, nutdriver for removal of VGA and DVI locknuts/capstands, cuticle scraper for removal of internal connectors and monitor case clips and a "Bennifiber" measuring scoop (to seperate the monitor case halves without scratching). Be careful when removing the aluminum insulating tape holding the connectors and planar boards down or it will tear. If you have "aluminum" duct repair tape it will suffice as a replacement. Also you will need to remove the tape on the sides to gain access to the screws mounting the cage holding the power supply and inverter assembly.
Jun 09, 2009 | ViewSonic VX922 19" Monitor Flat Panel
How to remove back panel
there might be screws behind the foot. remove the foot base first...then look to see. alot of these screens are pressure tab case fasteners.they use screws to lock in the cover. after that a smakk flat screwdriver along the lower sides will reveal is the cover is tab fixed .\
good luck
May 18, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Can't remove cover to check power supply.
Remove the bottom base according to user manual, clips into the bottom, pinch them together with your finger under the base. Then remove hinge cover in back of panel by popping off the plastic cover with a flathead screwdriver. Then remove the 4 screws holding the metal plate. Under the plate are two screws. remove them and then carefully pop the case open. The 2 screws are the only hard fixed part holding the case together, plastic snaps hold the rest. Also remove the 4 screws in the back of the unit. Remember where everything goes, write itdown, there are several plugin modules you will need to remove when disasembling.
Mar 31, 2009 | Westinghouse SK-19H210S Television
How do I get my Viewsonic VX922 LCD monitor apart? I have removed the 4 corner screws and the stand, but the back seems to be stuck solid.
in a similar situation the solution was an Ipod case opener used along the perimeter to release the plastic catches..
Mar 29, 2009 | ViewSonic VX922 19" Monitor Flat Panel
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Dec 28, 2006 | Dell E173FP 17" LCD Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
1,096 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
