Question about Samsung PCL5415RB 54" Rear Projection Television
Crt coolant leak onto pwb
I had this happen to me a few weeks ago on a pcl5415r. the tv was sparking from the bottom and a pwb (just above the bottom of the unit) caught fire. i wouldnt consider a cooling loop necesarilly a wear item and i was lucky i was right there when it happen to shut the tv off. would it be unreasonable to ask samsung to cover such a repair. i've got an estimate from the local samsung service place $500-$600. they showed me the oily spot when coolant had leaked onto a circuit board.
  • joeyrios Apr 19, 2008
    sticker shows september/2001 for mfg date. this appears to be a common problem, they should've issued a recall. these tv's can catch fire, and burn up a house. fortunately i was right there when the circuit board flare up and started burning. many times you turn on a tv a walk away for a moment. my two sisters in law have the same exact model part of the same purchase.
    Genius:
  • 1,694 Answers
No xtended warranty .......common problem bad seal(s) allow
leakage from CRT(s) onto PCB (s)........CRT replacement needed and PCB repair.....check out MO/YR made on sticker on back of set .................!...................T.
Posted on Apr 18, 2008
P0300: SOMETIMES rough idle, shake a lot OR less power above 50mph then got this code
Spark plugs in your car are good for 100,000 miles. try changing fuel filter and add a can of B&G 44K fuel additive. This stuff is the best on the market and only available at dealerships. It conditions fuel pump and injectors, also absorbs water in fuel (methanol). Try this first, your car is too new for any other problems. this should help drivability and fuel mileage. If Nissan does not have B&G, I know Toyota does. Also stay with 91 octane fuel. Check oil and coolant often. do not risk overheating in traffic, watch your gauges......
Feb 28, 2017 | Nissan Sentra Cars & Trucks
My 99 Saturn SL2 has recently been leaking the engine coolant. Every time I drive it, I need to put in a 1/4 to 1/2 bottle of coolant. It was overheating a couple weeks ago and I replaced the fan motor. A...
Take it to a shop and ask them to put it up on a lift, take a look and figure out where it is leaking. They can tell you and also how much to fix.
Oct 26, 2010 | 1999 Saturn SL
How do I disassemble a crt lense assy in proj tv? I have spider webs and bugs in all 3 assyd of my rear proj tv...
You will need to pull the complete crt assembly one at a time, Drain the coolant then remove the screws that secure the lens to the crt. But then you will need to replace the coolant. Do not try to loosen the lens while still in the TV or the CRT coolant will leak onto the chassis which can destroy the Chassis. You can get a CRT coolant kit at www.tvrepairworld.com which will contain the coolant and the Instructions.
Dec 12, 2009 | Televison & Video
Hitachi 43FDX15B TV
Symptom: DARK PICTURE OR MISSING COLOR
Cause: CLEAN SPARK GAPS, CRT PINS AND SOCKET ON CRT PWB
May 22, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Screen looks oval left and right
If I understand your description correctly, the picture essentially looks like this: ( ). In other words, the top and bottom are straight, but the sides look like the above.
This is a problem with the pincushion circuit. Plesae verify the model number of the set you have and I'll try to get you the probable parts that have failed.
Thanks,
Dan
May 05, 2009 | Samsung PCL5415R TV
JVC AV-56WP74 closes up and flickers when input is trying to come through
First possibility is a CRT coolant leak onto the signal PCB.
Examine from front and back with good light = even a few drops
of conductive coolant can cause various unusual symptoms....
Your symptoms are multiple and normally un-related, unless,
as you mentioned,all the signals converge......................T.
Nov 22, 2007 | JVC AV-56WP74 56" Rear Projection...
Red and Green flashes
Possible CRT coolant liquid leak onto circuit board.Check
for moisture evidence....................T.
Nov 03, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung HC-P4752W Blurred
im sorry for this not being a solution, but I have the exact same issue Jose. It just happened 3 days ago. When I run auto focus it says check factory default settings. Will replacing the 2 CI's help cure this problem.
Jul 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
1998 mitsubishi big screen model VS-50603
this model is famous for fluid leaks. each projector tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Jan 12, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
