The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Testimonial: "Thanks kitajib!!! - I did vacuum off the side of the MB when I put in the new NIC card but had may not have cleaned off the CPU. I will try your advice ASAP"
