microprocessor, integrated circuit containing the arithmetic, logic, and control circuitry required to interpret and execute instructions from a
computer program computer program, a series of instructions that a computer can interpret and execute; programs are also called software to distinguish them from hardware, the physical equipment used in data processing .
..... Click the link for more information. . When combined with other
integrated circuits integrated circuit (IC), electronic circuit built on a semiconductor substrate, usually one of single-crystal silicon. The circuit, often called a chip, is packaged in a hermetically sealed case or a nonhermetic plastic capsule, with leads extending from it for
..... Click the link for more information. that provide storage for data and programs, often on a single
semiconductor semiconductor, solid material whose electrical conductivity at room temperature is between that of a conductor and that of an insulator (see conduction ; insulation ).
..... Click the link for more information. base to form a chip, the microprocessor becomes the heart of a small
computer computer, device capable of performing a series of arithmetic or logical operations. A computer is distinguished from a calculating machine, such as an electronic calculator , by being able to store a computer program (so that it can repeat its operations and make
..... Click the link for more information. , or microcomputer. Microprocessors are classified by the semiconductor technology of their design (TTL, transistor-transistor logic; CMOS, complementary-metal-oxide semiconductor; or ECL, emitter-coupled logic), by the width of the data format (4-bit, 8-bit, 16-bit, 32-bit, or 64-bit) they process; and by their instruction set (CISC, complex-instruction-set computer, or RISC, reduced-instruction-set computer; see
RISC processor RISC processor [Reduced Instruction Set Computer], computer arithmetic-logic unit that uses a minimal instruction set, emphasizing the instructions used most often and optimizing them for the fastest possible execution.
..... Click the link for more information. ). TTL technology is most commonly used, while CMOS is favored for portable computers and other battery-powered devices because of its low power consumption. ECL is used where the need for its greater speed offsets the fact that it consumes the most power. Four-bit devices, while inexpensive, are good only for simple control applications; in general, the wider the data format, the faster and more expensive the device. CISC processors, which have 70 to several hundred instructions, are easier to program than RISC processors, but are slower and more expensive.
Developed during the 1970s, the microprocessor became most visible as the central processor of the
personal computer personal computer (PC), small but powerful computer primarily used in an office or home without the need to be connected to a larger computer. PCs evolved after the development of the microprocessor made possible the hobby-computer movement of the late 1970s, when
..... Click the link for more information. . Microprocessors also play supporting roles within larger computers as smart controllers for graphics displays, storage devices, and high-speed printers. However, the vast majority of microprocessors are used to control everything from consumer appliances to smart weapons. The microprocessor has made possible the inexpensive hand-held electronic
calculator calculator or calculating machine, device for performing numerical computations; it may be mechanical, electromechanical, or electronic. The electronic computer is also a calculator but performs other functions as well.
..... Click the link for more information. , the digital wristwatch, and the
electronic game electronic game, device or computer program that provides entertainment by challenging a person's eye-hand coordination or mental abilities. Made possible by the development of the microprocessor , electronic games are marketed in various formats, such as hand-held
..... Click the link for more information. . Microprocessors are used to control consumer electronic devices, such as the programmable microwave oven and
videocassette recorder camcorder combines a video camera and VCR in a single handheld machine.
The first commercially successful VCR, which used a Betamax format, was introduced in 1975. A competitive format, VHS (Video Home System), was introduced in the same year and became the dominant system.
..... Click the link for more information. ; to regulate gasoline consumption and antilock brakes in automobiles; to monitor alarm systems; and to operate automatic tracking and targeting systems in aircraft, tanks, and missiles and to control radar arrays that track and identify aircraft, among other defense
