Question about Lexmark X5470 All-In-One InkJet Printer
Im trying to Test my printer. Iwanna try print from the computer and its not working.
    Genius:
  • 3,587 Answers
Try this tip first
Posted on Apr 18, 2008
Won't print from computer
Try borrowing another suitable printer lead and test with that. If the printer can do a self test, it is likely the printer is not the problem. If that does not work, if you can, use another printer with your computer - but set it up first. Failing that come back for more help
Apr 21, 2014 | HP LaserJet 4L Printer
Hi, we have a GCC Elite XL 40N Printer at work on a network with about 12 computers attached to it. One day when I wasn't here, (so im not sure how it started) It started printing A LOT of sheets with...
This could be caused by a few different problems with the printer but here are some troubleshooting techniques that may help:
1. Check that the printer is able to print correctly on its own. Print out a configuration page from the printer or install the printer onto a new machine as a local printer and print out a test page. If this prints out as symbols, the problem is a most likely hardware error and the printer will need to be serviced. Try step 2 before servicing. If the printer prints normal characters, go to step 3.
2. Carefully go through the settings on the printer and review the printer's configuration page to make sure everything has the correct settings and nothing was changed accidentally.
3. The most common problem is that the drivers on the print server, or on the server computer, have become corrupted. In Printers and Faxes on the print server, delete all the drivers for the printer, reinstall them, and then add the printer again. Make sure to print a test page at the end of the add printer wizard.
4. It could be a problem with the ethernet cable so try swapping the current ethernet cable with a new one.
5. If it is still printing symbols at this point, it is most likely a hardware issue and the printer will need to be serviced.
May 24, 2011 | GCC Technologies Elite XL 40N Laser...
I need help faxing, saying its incomplete
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer goes through the motions but text does not print
Let's first test the printer independant of your computer:
Try printing a test page using the instructions here: http://www.ehow.com/how_2006016_perform-test-epson.html. I hope your model printer is listed there. If not, try to find instructions specific to your model in your model's user guide or elsewhere on the internet.
If this works and printing from your computer doesn't, then:
(???Bad print drivers???) Reload the print drivers on your computer.
(???Bad cable???) Try replacing the printer/USB cable that connects this printer to your computer.
(???Bad USB port???) Try using a different port to connect the cable to your computer.
If none of this works you either have a faulty ink cartridge or a more serious issue with the printer. Depending upon the model, unfortunately, it might be cheaper to replace than repair.
May 28, 2009 | Epson Office Equipment & Supplies
HP Laserjet 1200 will not print if installed on new computer
check to see if you are trying to print offline...
May 26, 2009 | HP LaserJet 1200 Printer
Prints pages with no words but symbols
Print test page from the printer. This prints fine? Then anytime a printer prints gibberish versus what you were trying to print from the computer means you should try one of two things. Download the most recent drivers from the products support site, install these. Be sure to uninstall the old drivers first. Another item that can cause gibberish print is a bad cable. Swapping out with a known good could solve the whole problem.
Print test page from the printer. This does not print fine? Then you are looking at something wrong with the printer. The cable and drivers would not be the cause because the only piece of equipment involved at this point is the printer. First step I would try in solving this. Download and update the firmware from the support site. If this does not work, then you may have a defunct printer. If you are under warranty, contact Dell tech support.
Mar 12, 2009 | Dell 1600n All-In-One Laser Printer
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button down on the front of the workstation/computer/tower/CPU until the unit turns OFF)
(2) If that doesn’t work, then try clearing the print queue: Start>Settings>Printers>Double-click on the printer>Right-click on the print job(s) and click cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Jan 02, 2009 | Dell 540 Photo Thermal Printer
Printer not printing
Uninstall everything. Reboot. Unplug the printer. Install the software. Reboot. When everyting is up. Plug in the printer. Have the driver disc ready, install the printer. Reboot, go to settings, printers and see if the printer is listed. If it is, make it the default printer.Good luck
Dec 20, 2008 | Computers & Internet
Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Sep 04, 2008 | Canon MX700 Office All-In-One InkJet...
I have installd my Lexmark 6200 but it just wont print any of my documents that i need to print im not a computer wizz and have next to no eperiance with computers please help me i only want it to print...
try to take test print page by going to start-settings-printer and faxes-right click on the your printer name and model - click on properties then click on test page, if you are able to get the print then your printer is ok if not then reinstall the drivers and then try
May 16, 2008 | Lexmark Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
