Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Forgot my admintration password
My daughter forgot her admintration password and she is the only one can login on to her computer. PLEASE HELP
    Novelist:
  • 84 Answers
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Posted on Apr 22, 2009
    Master:
  • 351 Answers
Dear ,
If that�s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP. This method is easy enough for newbies to follow � it doesn�t require using the Recovery Console or any complicated commands. And it�s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repairandrecovery/locksmith.asp
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here�s how with a step-by-step description of the initial Repair process included for newbie�s.
1. Place your Windows XP CD in your cd-rom and start your computer (it�s assumed here that your XP CD is bootable � as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be �Press any key to boot from cd�
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like �If one of the following Windows XP installations is damaged, Setup can try to repair it�
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically � you will see a progress bar stating �Your computer will reboot in 15 seconds�
9. During the reboot, do not make the mistake of �pressing any key� to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you�ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
  • Go to the Control Panel and open up User Accounts.
  • Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
  • This will initiate a wizard.
  • Click Next and then insert a blank formatted floppy disk into your A: drive.
  • Click Next and enter your logon password in the password box.
  • Click Next to begin the creation of your Password disk.
  • Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account.
Note: If your computer is part of a domain, the procedure for creating a password disk is different.
See here for step by step instructions: http://support.microsoft.com/default.aspx?scid=KB;en-us;306214&
Posted on Apr 15, 2008
How to reset windows 7 password if forgot?
Rescued the neighbor's daughter's laptop recently with TunesBro. Took less than 5 minutes to recover the password. Was an Windows 7 machine though... Forgot Windows 7 Password Can Reset Windows 7 Login Password
Aug 16, 2017 | The Computers & Internet
Daughter forgot password on syvania netbook how can i reset it
Really try hard to remember. Options are not good.
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is availible) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 01, 2012 | Sylvania G-Netbook
Windows ce forgot password
try to login in safemode to delete password in user account
Mar 07, 2012 | HEWLETT-PACKARD Computers & Internet
My daughter has forgot her password for her acer aspire one netbook and we cant get logged in, car you help
You can try to login in safemode and change the password there. just spam F8 at startup and login as administrator.
another thing is this guide:
http://geeksaresexy.blogspot.com/2006/01/forgot-your-windows-password-no.html
I hope this helped ;)
Mar 29, 2011 | Computers & Internet
Hello sir /mam i have a problem is my daughter
If the password is stolen then please go ahead and login to www.yahoo.com
1. Enter your user name 2. Click on forgot password 3. Answer the secret question you had chosen earlier and then your password will be reset and you will be able to login again in your account
Mar 29, 2011 | Yahoo Mail
I have a facebook account, my daughter setup a facebook account,also on my computer, now I can't login to mine.
Having 2 or more Facebook accounts set up on Facebook from the same computer should not cause a problem as each facebook account uses a different e-mail address... if you click on "account" (top right) in your daughters facebook page, there should be a "log out" link in there...click that and it will take you to the facebook login page, where you should be able to log in with your details to your account
If you still cannot log into your account, click on the link that says "i forgot my password" and they will send you the password if you have forgotten it.
Jan 27, 2011 | Computers & Internet
I Forgot my old facebook password and i can't login i Need A New Password Help Please
On the Facebook login page click on Forgot Password? and follow the instructions to reset your password.
Dec 18, 2010 | Facebook Social Network
I need to delect/cancel my daughters myspace
you should retrieve your email address first example if you are a yahoo member it is easy for you to retrieve it. cause once you forgot your password you can easy click the forgot password below the login portion of the web. then once you click it the browser will drag you automatically to the information sheet so that you will fill out the form if you own that account or email address. I hope this one will give you an idea how to fix your problem. God speed.
Apr 10, 2010 | MySpace Social Network
On the welcome screen password my daughter changed her password and now forgot it. Its a dell inspiron 1545 and it has windows.How can I reset or fix this problem?
If your account on your computer is an 'Administrator' account, you can login to your account, and you can change the password for her account.
Jan 08, 2010 | Dell Computers & Internet
Forgot password
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Jan 12, 2009 | Acer Aspire 3680 Laptop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
221 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
