Question about Sony Ericsson W850i Cellular Phone
Display dim My W850i's display is very dim after it got soak in water. I've change the LCD module but same problem still occur. Pls advise.
  • slow_racer Apr 18, 2008
    yea i got the same problem.  my backlight doesnt even go on, on the lcd or the keypad. but when playing songs the orange light works... strange..
    Sergeant:
    Champion:
  • 283 Answers
It was the display ic., and combiner to produce lights it got grounded ..gotta go to center and fix the light combiner or capacitor..or the display ic... but if it is backlight problem of the lcd.. go to the light combiner capacitor and not to the ic..
Posted on Apr 17, 2008
The display is dim and hard to see.
First, make sure that your brightness is turned up. You can access this from the menu by selecting "Display" then adjusting the display between 50% & 100%.
If the brightness is at 100% and the display is still dim, this is an indication that there is a problem with the backlight that lights up the LCD display from behind.
The backlight is integrated into the LCD display, so the entire display needs to be replaced. Was the unit dropped? If so, perhaps the LCD flex cable pulled out of the connector, slightly from one side, disconnecting the backlight. We strongly suggest that you don't try to repair the unit yourself. Additional damage can occur.
More information on LCD repair can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 14, 2014 | Garmin nuvi 1300 Car GPS Receiver
Vizio vo37l backlight rapidly flickers when dynamic contrast tries to dim the display
I agree that the problem is most likely on the inverter board. I repaired a Vizio 42" LCD with the same problem, it was bad capacitors on both inverters. Cost $2 to repair. Take off the back cover to the set and check the capacitors on both boards. If they have bulging tops, that's your problem.
Oct 03, 2012 | Vizio VO37LF 37 in. LCD TV
How should i remove water stains in my cell?
It sounds like the phone's screen capillaries soaked up the water, and unfortunately there really isn't much you can do aside from replacing the LCD.
Replacements range from $20 - $30 on amazon and ebay. If you've ever worked on an iPod and were successful, this should be a cake walk to do.
People have tried using alcohols or ammonia in these cases, but those are risky solutions and are likely to further damage the LCD. I would advise against using any chemical fixes.
You may also get lucky; it's possible that the water trapped within the screen capillaries may evaporate over time.
Sep 10, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Marantz CD4000 dim display fix?
CD 4000 have two types of displays. Flourocent type and LCD type. It yours' have flourocent type, the display module is faulty. If it is LCD type, backlight LED is faulty. This LEDs can be replaced.
Jun 05, 2012 | Marantz CD-4000 CD Player
Monitor display message : = No Video input. Pls
if cables are ok; Take your computer down to the repair shop.
Jun 20, 2010 | Philips 170S4FB 17" LCD Monitor
My headlights come on automatically even during the day; also the lcd display on the clock and temperature displays are too dim to read during the day. Can you advise what might cause this? GMC 2000 Safari...
As a rule you will likely need a new daytime running light module,some GM's need the instrument cluster replaced because the module is built into them,check with the dealers parts department.
Apr 13, 2010 | 2000 GMC Safari
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
W850i sony ericsson
it may be pro in display..so better change ur display else reinstall ur mob software else change display ic alone
Jul 31, 2008 | Sony Ericsson W850i Cellular Phone
Sony ericsson w850i
take the phone to a service center and have it reflash......and service
Dec 14, 2007 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
158 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
