Question about D-Link DI 514 Wireless Router (DI-514)
Can't bring up Setup Wizard
I type in the correct address http://192.168.0.1 but the setup wizard does not appear. It comes up with other searches for related topics. Please help.
Yeah the same problem. not able to launch the wizard from the URL.
Actually i was trying to change the password for the wireless secure access and i tried typing different combinations and got in problem, then thought of doing a reset and start again the whole configuration, so i did used the reset hole and followed the instructions as listed in the document (ie like doing the configuration for first time). after restarting computer and access the http://192.168.0.1 URL, nothing happens, i'm not able to get the setup wizard. I also noticed that the LEDs are displaying properly as mentioned in the manual... now.. how to get it setup wizard....
plz help
Posted on Apr 15, 2008
plz help
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
My 2wire product seems to need resetting every few minutes. As soon as it's unplugged and plugged back in, it works. However, after a few minutes, it loses connection again. Is this an issue with my ISP,...
  • Re-run the Setup Wizard using one of the following methods if you are unable to browse the Internet:
  • Re-run the HomePortal Setup Wizard from the HomePortal CD.
  • Re-run the HomePortal Setup Wizard by going to http://homeportal/setup (http://172.16.0.1/setup) in your Web browser.
  • (For Windows only.) Re-run the HomePortal Setup Wizard by clicking Start > Programs > 2Wire Gateway > Run 2Wire Setup Wizard.
If required, make sure that you are using your unique username and password. If the problem persists, contact your ISP to verify your connection type and login information (if necessary). After verifying your connection type, also verify that you are using the correct keycode by referring to your HomePortal documentation or by visiting http://www.2Wire.com/keycode.
Nov 04, 2010 | 2wire (1000-000057-000) Modem
I am trying to set up a used router, but can't get
Not at all unfortunatelly.
First make sure if you run first setup from CD already. If no then do it, if yes then
Setup wizard runs through browser.
Try to run it like that:
1. Open browser (firefox, internet explorer, opera, whatever)
2. type in address bar: http://192.168.0.1
3. There should appear enter username/password
4. Defaults are: login: admin, password: 1234
Cheers,
Mike
Leave rate if I helped you, thanks!!
May 08, 2010 | NetGear MR814 Wireless Router
I dont know how to access setup wizard for cwr-854 cnet router
To access Router type that --> http://192.168.1.254 into your browsers address bar, a password & logon box should appear, The USERNAME is root The PASSWORD is 1234
Now you should be able to access wizard.
Here is a better manual.http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20Quick%20Install%20Guide.pdf
Feb 09, 2010 | Computers & Internet
I have a wireless d link router di-614 i never set a password and would like to now. How do I do that? Thank you.
Here are the steps on how to set a password on your router.
Open your Web browser and type "http://192.168.0.1" into the URL address box.
Then press the Enter or Return key. The logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
Click OK Once you have logged in, the Home screen will appear.
Click Run Wizard. You will see the following screen.
Next Step 1 - Set up your new password. You have the option to establish a password.
Click Next Step 2 - "Choose your time zone", you will be prompted to select the type of Internet connection for your router (see next page). Click Next The Setup Wizard (continued) Select the type of Internet connection for your router. Select one of these settings If you are unsure of which setting to select, please contact your Internet Service Provider.
Click Next If you selected Dynamic IP Address, this screen will appear:
Click the "Clone MAC Address" button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. What is a MAC address? Each network adapter has a discrete Media Access Control (MAC) address. Note that some computers and peripherals may already include built-in network adapters.
Click Next If your ISP requires a Static IP Address, and this option is selected, then this screen will appear: Do not use Enter the IP address information originally provided to you by your ISP. You will need to complete all the required fields. the numbers displayed in these fields. They are only shown as an example.
Click Next If your ISP uses PPPoE (Point-toPoint Protocol over Ethernet), and this option is selected, then this screen will appear: Enter in the username and password provided to you by your ISP.
Click Next The Setup Wizard (continued) Wireless Setup The default wireless settings are: SSID = default Channel = 6 You can change these settings to match an existing wireless network.
Click Next Encryption The DI-614+ is capable of three levels of wireless encryption - 64bit, 128-bit, and 256-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication.
Click Next Your Setup is Complete! Click Restart Click Close You will be returned to the Home tab. Test Your Internet Connection
Click Exit Then relaunch your Web browser
Jan 22, 2010 | D-Link AirPlus DI-614+ Wireless Router
Lost my setup wizard cd for a X-Micro XWL-11GRIX router
First, Go START | RUN... and type CMD.
When black windows apears, type ipconfig and write down the gateway. This is the address you have to use on your browser. The router will most probaly ask a login and password. Try admin for login and password. It change form manuf. to manuf. Search your Manual for Default Password.
Jul 12, 2009 | X-Micro Technology (XWL11GRIX) Router
Netgear dg834gt problem connecting to hp pavilion dv4000
HI
NOTE: The following setup info .is for da PPPoA connection type.(most common in UK).
Its advised to keep da ethernet connected to your laptop untill you configure da wireless on the router, you can disconnect da ethernet cable after the confoguration is over to connect wirelessly.
Try the following: check if your PC is communicating correctly with router. (You might need to restart the computer, after the router is connected to it). On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window
Type command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below.
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then your PC is not communicating to the router. In such a case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note down the values of IP Address and Default Gateway. Close the command prompt window.
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of a Netgear router it should be 192.168.0.1
It should bring up the logon window similar to the image below. Type the router username and password in the respective text boxes. Refer your product manual for the default Router username and password. In case of most Netgear routers, default username is admin and password is password. Then click on the Login button to continue.
In the next window that appears, click on the setup wizard button
This should bring up the Setup Wizard page similar to the image below. Select Country as UK and Language as English. Under Auto-Detect Connection Type, select No. Then click on Next button.
Basic Settings page will appear. Under Does Your Internet Connection Require A Login?, select Yes.
Configure the following settings in the window:
  • Encapsulation: Set it to PPPoA (PPP over ATM)
  • Login: Type your login name. (in most cases its the primary email address that you get from your ISP)
  • Password: Type you account password. (make sure there are no spelling or case mistakes)
  • Service Name: Leave blank.
  • Idle Timeout: Set to 0.
  • NAT: Select Enable.
Now click on the Apply button. (Please note that it may take up to 5 minutes to apply the new settings)
Then ckick on da wireless settings option.( its on the left pane on the window).
- keep the channel as 11.
- mode can be g&b
Make sure that da option WIRELESS ACCESS POINT is enabaled.
Also check da security options .... I would suggest use WPA-PSK encryption.
make a note of da shared key(network password).
ckick apply and wait till it saves the settings.
Disconnect the ethernet and try connecting to the wireless network with the correct security key.
Hope this helps you.
cheers
SHADAB
Sep 07, 2008 | NetGear DG834G Router
Belkin
Yes there is just follow the following:
To setup your Belkin Router please follow the steps below.
Once the router is connected, check if your PC is communicating with the router. On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window.
Type the command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then the PC is not communicating with the router. In this case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note the values of IP Address and Default Gateway. Close the command prompt window. The default gate way for belkin is 192.168.2.1
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of Belkin router it should be 192.168.2.1. Then click on the Go button.
It should bring up a screen similar to the image below. Refer the product manual for the default Router password. In case of most Belkin routers, it is blank. So, just click on the Login button.
This should bring up the Belkin Router Setup Utility. Click on the Wizard link on the top bar of this page. In the Connection type options, select PPPoA. Then click on Next button to continue. Notice that on the top right side of the page, it says "No Connection". Once the setup wizard is complete, it should change to "Connected"
In the next window that appears, enter the broadband email address and password in the respective boxes. Then confirm the password in the Retype Password box. In case of VPI/VCI:, type 0 and 38 in the left and the right boxes respectively. Then click on Next to continue.
Click on the Apply button to save the settings.
It may take up to 5 minutes to save and update the settings. Once completed, you will see, "Connected" on the top right side of the window. Once you see that close this window and open your browser window to go to any website.
May 17, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Easy Install wizard problem
What you can do to fix this problem is not use the install program at all.
To configure your router, in your web browser's address bar, put the IP address of your router (Another belkin router's default IP was 192.168.2.1 out of the box) and click on go. This should bring you to the routers setup, and the password by default is blank.
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
Software problem
There is usually an IP address you have to type to get access to this hardware. Often you don't need the CD to install this hardware. The IP address is usually 192.168.0.1 for routers. Sometimes they differ. To find out if you go to start then run. When a box appears type in there cmd then press enter on your keyboard. This should bring you to DOS. Black page with white text. If you type into that box ipconfig and then press enter on your keyboard.The IP address you see net to the default gateway is your router address. Writed down those numbers and that box you are in just type the word exit and press enter on your keyboard and that box will disappear.Type that IP address into your address bar by opening up your browser. This will bring you to the hardware page of your router.You can do all the confguring from this page. Sometimes a box with user name and password appears. The username is usually admin and the password is either password, admin or these is no password so you just press enter on your keyboard and then when you're in start configuring. Run the setup wizard first before you do anything else. Then I would go to wireless and password protect your network. I usually password the router as well. This option is in the setup wizard you did earlier. Good luck
Jan 21, 2008 | Actiontec GT701AP (DNHGT701AP) 802.11b/g...
D-Link DI 514 Wireless Router (DI-514) Logo
722 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
