Question about Canon PowerShot SX100 IS Digital Camera
Lens error, restart camera on Powershot SX100 IS
  • 7 more comments
  • Anonymous Jun 03, 2008
    took batteries out and memory card overnight - reinstalled next day - nothing happened same problem
  • angieshair Jul 26, 2008
    i hve taken out the batteries and the card and nothing happened. The store Sears refused to take it back because it was a clearance item. Now I have a New camera I cant use.
  • ghytg Nov 29, 2008
    mee too how the hell do you restart is my question
  • loso Dec 07, 2008
    me to same thing as the others
  • Anonymous Feb 25, 2009
    what's the hell am I gonna to do now:((?
  • Anonymous Mar 02, 2009
    its really hard to believe but most of teh people is facing the same problem, its really a horror dream to hae the camera of Canon, Now I will prefer nokon Rather
  • Anonymous Apr 13, 2009
    Same problem as the rest, how do you reset the camera?
  • Anonymous Apr 14, 2009
    The same as everyone else what a piece of ****:(
  • Golem Apr 16, 2009
    Canon P.O.S. Lens stuck in extended position. Lens error, restart camera. E18 error. I had this problem before and solved it by smacking the camera on its left side while turning it on but it's happened again and smacking it doesn't work now. This and other Powershot cameras have the same problem. I will never buy Canon again!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 98,921 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
  • 11967 Answers
SOURCE: lens error, restart camera message is appearing...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 04, 2010
SOURCE: Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Posted on Apr 22, 2008
t00nz
  • 4738 Answers
SOURCE: Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jun 28, 2009
SOURCE: Canon Powershot SX10 lens error
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Posted on Aug 30, 2009
CanonAssist
  • 5 Answers
SOURCE: lens error, restart camera canon powershot
The best thing to do is to first try restarting the camera. Do not push or pull on the lens as this will often cause other issues. Do not blow air in the lens as this generally moves any dirt or dust to the back and it sits on your imaging sensor, you'll end up with poor photos after that. The best thing to do is to have it serviced so it is fixed correctly and working the way it should be. The site that is great for the Powershot Models is: www.CamerasAndParts.com They only specialize in these Powershots and they have your exact lens error problem right on the site. Try them for help. They tend to be the best deal plus they're service is wonderful. You'll pay $89 for the repair, all of the service for that model and the return shipping back to you included with them. They'd be the place for help with this one, best of luck.
Posted on Jun 27, 2010
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Dec 11, 2009 | Canon PowerShot SX100 IS Digital Camera
My Canon Power Shot SX100 IS says lens error. restart camera. Help
Aug 24, 2009 | Canon PowerShot SX100 IS Digital Camera
Ny power shot camera SX100IS says lenserror, restart camera. How do I fix this problem
Aug 16, 2009 | Canon PowerShot SX100 IS Digital Camera
I keep gettin lens error restart camera on my canon powershot sx100 and the lens wont retract. I have turned it on and off several times now. Is there anything i can do to get it working again?
Jul 21, 2009 | Canon PowerShot SX100 IS Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens Error
Unfortunately this Canon SX100 (and the SX110 too) has a very fragile lens assembly. Once you have this lens error problem, there are only four solutions: 1) If it's under warranty, contact Canon to make it valid; 2) If not, then have a repair center to replace the lens assembly (either the internal lens motor or the gears are damaged) or, 3) Sell it for parts or 4) send it to the trash can.
Jun 28, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens error
sir,problum is ur lens unit,some mechanical or dislocations,gears this is repairable u try ur local service center
Apr 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
316 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
