Question about Samsung HP-T5044 50 in. Plasma TV
Flickering I have a 50" plasma tv(Samsung) and it is 9 months old. It just started flickering with a light staticy appearance. when I shut it off and turn it back on it goes away for awhile. If I leave it on while it is doing it, it gets worse and starts making crackling sounds also. If anyone can help me it will be appreciated
  • 2,336 Answers
I would suggest to call Samsung to get the Plasma repair under manufacturers warranty. The flickering will not go away until the hardware failure is corrected.
Good Luck.
Posted on Apr 15, 2008
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
Flickering screen, loud buzzing sound, self boot down.
Color wheel bad. Makes rumbling sound. Bad bearings. Has to spin about 10,000 RPMs and sync to DLP chip. Here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5933777&smodel=HLR5067WX/XAA
May 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung TV flickering image
You seem to have what is called error diffusion. Either call samsung about it and arange service or do it on samsung.com. What kind of warranty do you have? Depending on your date of purchase you might be able to get samsung to help cover it or pay for it all.
Mar 09, 2008 | Samsung SP-S4243 Television
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Samsung HP-T5044 50 in. Plasma TV Logo
522 people viewed this question
Jerry Greenberg
Jerry Greenberg
