Question about HP PSC 2210 All-In-One InkJet Printer
Can not send or receive faxes
Lines have been checked, all OK after a lightening storm have not been able to send of receive any faxes, copier, printer and scanner all works OK.
    Problem Solver:
  • 14 Answers
You may have to reset printer. Directions as follows:
Re-initialize the HP All-in-One Force the HP All-in-One to reinitialize by following the steps below:
  1. Turn the unit off by pressing the ON button.
  2. Disconnect the power cord.
  3. Wait five seconds, then reconnect the power cord.
  4. If necessary, turn the unit back on and try fax again.
  5. If the unit fails to read the card again, reset the All-in-One. Repeat Steps 1 – 4, but before plugging the unit back in, press and hold the # and 6 keys on the HP All-in-One numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the All-in-One reestablishes communication with the computer, reset the language and country/region.
You may have to reset the fax at this point.
Posted on Jun 13, 2008
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Unable to send or receive fax
Try uninstalling and reinstalling the drivers for this printer, you can get them from the HP website
Let me know how this goes and whether you need any help doing this or if you have any questions
If this doesn't work then I have a few other ideas for what it wrong.
You could also try a system restore if the drivers don't work
Jun 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Cannot receive faxes
The storm has likely damaged the phone line, or the ADSL microfilter (if you have one). Which is why it thinks a phone on the fax line is off the hook. Check your line for breaks and your ADSL filters for a blown filter.
Sep 18, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
My HP fax 6500 is sending fax but is not receiving fax
There could be several reasons for it. the basic one is..
Press SETUP Button on front panel
Scroll to Fax setting or Advanced Fax settings - Press OK
Check for Error Correction Mode or ECM - Press OK
Turn the ECM Off - Press OK
Try to receive fax.
Oct 29, 2010 | HP Officejet 6500 Wireless All-in-One...
I have received a fax and it has to vertical lines down the front of it.
The problem is with the SENDER's fax machine ... not yours...
Your fax machine is working properly...
Note that all faxes from that source will have the stripes, all other faxes that you receive from other sources will not have the lines...
You might send the fax with the lines back to the sender to advise them...
Hope this helps!
Sep 09, 2009 | HP Office Equipment & Supplies
I am having trouble faxing documents. Whenever I
Hi, you can check that your phone connection from your 7420 to line works. Listen for a dial tone in a phone connected to your mfc7420. If not, your tel comm module could be at fault.
Jul 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Phone line goes to fax
Lightening is definitely a factor. When you say it defaults to fax, do you mean that the fax machine picks up as soon as the phone rings? Most likely the fax software/machine has taken a hit. One way to check is to try it on another phone line, preferably at another location. So the cordless phones work all right? The static is probably something the phone company will have to fix. They have lightening arresters that will develop those conditions. Again, try a known good phone on the line. Preferably disconnect all the phones at the junction box where the phone line comes in and plug a known good phone into the jack. If you still get static, then the phone company should get involved. Otherwise you could have a problem with the house wiring.
Jun 19, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp laserjet 3030 fax
i have hp laserjet 3030. i cannot send or receive fax messages. i have checked with other machines as well. a beep sound is heard and there is no answer. my fax and phone lines are working fine.please help me as early as posible.
Sep 27, 2008 | HP LaserJet 3030 All-In-One Printer
Sending and receiving faxes problem
you may have a scanner problem, this should be checked by a locaal brother serice cemter. thanks brother tech
Aug 28, 2008 | Brother MFC-8440 All-In-One Laser Printer
HP PSC 2210 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
