Question about Kidde Nighthawk Combo Gas/co Detector
Alarm keeps beeping, reads 0
Our alarm (900-0113) has sounded briefly (3 short beeps) 3 different times today.  The display continues to read "0", nothing else.  I changed the battery thinking that was the problem, but it happened again since then.  I am thinking that it is malfunctioning since it still reads 0 after testing it.  There is a blinking red light next to the 0 which, according, to the manual, means it is working.  I have two small children at home so do not want to misdiagnose.  Thanks.
  • 667 Answers
Try testing it first. Press the test/reset button. If it's operating properly on the display:
"GAS" - and it should beep 3 times. Then a number should appear on the display. It should be arround 200. Then it should beep 4 quick times, then nothing for 5 seconds, then 4 quick beeps that keep repeating. It will then show 3 numbers again for a few seconds. When they're gone it will be done resetting. It should show a flashing red light and a 0 or whatever the reading might be. Try this and let me know what happens. If this fixes the problem please rate as fixed. If not, please don't rate yet. Let me know what's going on and I'll be more than happy to help. Thanks.
Posted on Apr 16, 2008
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Apr 28, 2012 | LG Refrigerators
I have model does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
PC power on but doesn't display anything on the monitor and has a beep code of different intervals of time. Here are the beep codes: 2 beeps, after 1 sec, 8beeps, after how many seconds 2 beeps after how...
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to:
Jan 09, 2011 | EliteGroup P4VXASD2 Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here:
Aug 16, 2008 | Dell XPS M1530 Notebook
Kidde Nighthawk Combo Gas/co Detector Logo
594 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
