Question about GE 106591 Coffee Maker
GE coffee maker
Have had this coffee maker only 3 months, Model169123. It gets used once a day every day. You would think you could expect at the least that. It is now junk. Won't work at all. Stopped in the middle of brewing a pot. Looking at the bottom of the appliance it is clearly marked Wal Mart. Getting anything done about it is out of the question. Wal Mart just wants you to purchase another one. Can not disassemble and find parts because apparently we are not smart enough for that anymore. If you buy a product like this from a good retailer, such as Costco, they would stand behind what they sell. GE should be embarassed marketing this chinese junk for Wal Mart. Wal Mart has really got Paul Harvey snowed don't they. Wonder what they pay him?
  • GE Master
  • 5,568 Answers
If it failed after working a short while, the thermal fuse used in all drip coffee makers is frequently failing and we have had exactly the same experience with another brand. Our toxic Chinese friends are making crappy thermal fuses along with about everything else.
Replacing these is impractical since they are in a small metal case, pointed on one end with two coaxial leads permanently attached. Further, they are welded  to wiring under the warming plate to the heating element. The area is too hot for solder and ceramic wire nuts have to be used to replace the fuse and these are tough to find anymore.
Bypassing them is a really bad idea since I know of one case where the thermal switch that causes the machine to cycle, failed, the heating element melted through the aluminum plate on the bottom and set fire to a kitchen counter.
With the cost of labor being what it is, hardly any of these drip coffee makers are worth repairing.
Posted on Sep 28, 2008
Got my 12-cup ge coffee maker 3 years ago and within 3 months the lid began to crumble so I duct taped it but now the entire lid is covered with duct tape. Called them to replace the lid and they told me...
It is a matter of economics. Even if the lid were available, it would cost more to replace it than to simply buy a new coffee maker. I understand your frustration.
Jan 08, 2014 | GE 106591 Coffee Maker
Cuisinart coffee pot
his EXACT situation happened to me 2 days ago because it gets clogged. Flush and dump clear HOT water threw the tank several times. When I did this, clumps of coffee came out and the coffee maker worked great again. In hindsight..it was my bad because the manufacturers say to run a clear vinegar flush threw them once every 6 months, followed by 2-3 clear water flushes to remove these "clots" that plug it up. Hope this info is not too late and you didn\'t throw your machine out. :)
May 07, 2013 | Coffee Makers & Espresso Machines
Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Jun 20, 2010 | Keurig B60 Coffee Maker
Bunn automatic coffee maker will only make half a pot, this is a commercial unit with 3 burners
try cleaning with white vinegar(50/50 with water)may have calcium deposits supposed to clean once a month-let it soak overnight use coofee filter to catch deposits run numerous times then throughly rinse with water!!! :)
Jul 04, 2009 | Bunn NHB Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
Ge coffee maker
Old message, you probably have had a few machines more by now.
If bnot, take it back; the bimetal thermal switch that is responsible for cycling the machine is 'bad.' Actually, it's Chinese and they haven't quite figured out how to make these reliable.
This type of switch has been around for 3/4 century and those made in the US were only used for protection and cycled only to prevent fire in some equipment. Because they are a sandwich of two metals, they flex to switch when their design temperature is reached. Just because of metal fatigue, they really aren't intended to switch off and on several times a minute as they must in a drip coffee maker.
Mar 01, 2008 | GE 106591 Coffee Maker
GE 106591 Coffee Maker Logo
122 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
