Question about Canon PIXMA MX310 All-In-One Printer
FAX STUCK IN MEMORY REPLACED THE INK CARTRAGE
I NEED TO CLEAR THE IN USE MEMORY / ALARM.
KEEPS SHOWING CHECK PAPER SIZE
    Problem Solver:
  • 5 Answers
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
Hi how do i stop receiving fax's i get sent junk everyday and it waists my ink cartrage? Cheers Steve
use service code 7227 to delete all faxes from memory:
press:
MENU
45
OK
7227
right --> YES
OK
they are goners.
Feb 15, 2011 | Philips Magic5 Voice DECT Duo - Fax /...
I have a mfc620cn. I have replaced the cartridges
This error code means that the size of the paper your machine prints onto is different to the size that it has received from another fax....take your paper out and adjust the side guides put the paper back in and then see what it says...
There may be a button on your console that says 'memory' or
"memory status". pressing this key should erase any documents in the memory.
if none of this works turn it off and leave it off overnight, if in the morning when you turn it back on the memory should have been cleared....dont turn it off at the machine turn it off at the wall socket so the machine thinks there is a power failure...this should make the machine print out a status report when you turn it back on.
The above is for the fax problem. For the unrecognized catridge:-
This is a usual problem observed in times of loose connection or dirty catridge contacts. Please make sure that the catridges are clean ( especially the contacting end ). Try cleaning with alcohol.
Sep 14, 2009 | Brother MFC-620CN multifunction Color...
Machine keeps printing symbol codes till all paper is empty
It sounds as if you have scanned/faxxed a lot of things from this machine. It is just that you need to clear the memory. Remove all paper so that it is not wasting ink or paper. Turn the unit on and navigate through the menu until you come to pending jobs and clear them and then clear the memory. Hope this helps!
Mar 16, 2009 | Panasonic PanaFax UF-8000 Laser Fax
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax
From the manual:
If ink has run out while receiving a fax, if the paper size setting is incorrect, or if the paper type is set to a type other than plain paper, the fax is automatically stored in memory and <Received in memory.> is displayed. When the ink tank is replaced or the paper size/type setting is corrected, the stored fax is printed automatically.
Also, if the machine is in the process of something else (printing from computer, making a copy, scanning to computer), when a fax comes in it will be saved to memory, but it should print within a few minutes of becoming idle again.
May 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax L200 Check paper size problem
This is due to the reg sensor being worn, item 26 in the photo
please order and replace
RB2-1700-030 - LEVER, REGISTRATION SENSOR
hope this helps
Mar 06, 2008 | Canon FAX-L200 Plain Paper Laser
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Received in Memory
check the paper sensor at the bottom of where the paper comes out! this has a tendency to pop out of its little holder. Use a flashlight to see it! the sensor is blocking the beam.
Dec 07, 2006 | Canon CFX-L4000 Plain Paper Laser Fax
Canon PIXMA MX310 All-In-One Printer Logo
209 people viewed this question
old marine
old marine
