Question about SanDisk Sansa e260 MP3 Player
Did my BATTERY short, or my whole PLAYER?
OK, so I'm not the first one here to have this happen, but my girlfriend VERY briefly dropped my e260 into a half-inch of water while it was on. She said it continued working for about 10 minutes, then suddenly turned off.
Attempting to turn it back on yielded the blue ring lighting up and a white screen.
So, I took off the back, took out the battery, took apart the actual case, and let it dry for a while. There seemed to be very little water inside, none in the screen or anything, just a few small drops under the main buttons.
I reinserted the battery and VOILA, it started up just fine, just like normal, and I played a song to make sure....yup, all was well.
Except it seemed to keep turning on by itself every minute or so. So I put it on HOLD.
Then I put it all back together, screws and all. Let it sit for 15 more minutes, and then when I turned it on to listen to it..... it wasn't working again! I get the blue ring only, no screen, and it appears to shut off after 15 seconds or so.
Alright, so I plugged it into my computer, and despite it APPEARING to be off, I was fully able to access my song files, copy them off the Sansa and listen to them on the comp...
So my question is, is it likely that my BATTERY has somehow shorted out, causing it to not properly power the system? I wonder because obviously I was able to establish that the player still worked fine (temporarily) and I could access all my files.
Or is it more likely that my PLAYER shorted out, but---slowly? Can it short out 'over time', as in, get better then suddenly worse again, even though it was getting drier?
I'd like to think it was the battery, and simply get a replacement, but anyone who has knowledge of things shorting out, how it happens etc... I would greatly appreciate your feedback.
THANK YOU!
  • 8,596 Answers
I have yet to see an Mp3 player that can survive a water drop. You can "dry out" the player, and it may work sometimes. Replacing the battery most likely will not fix.
Posted on May 23, 2008
Where is the processing chip on the AMP'D 4gb MP3 player, the one from the prison, and How to reset it....
Does any1 know how to unlock the AMP'D MP3 player the ...
www.fixya.com/.../t14117772-any1_know_unlock_amp_39_d_mp3_pl...
Jan 28, 2008 - Its the clear MP3 Player you get in prison ... Contributor; 1 Answer ... I have just got a used AMP'D Maxx mp3 and I would like to get the .... SanDisk Sansa E260: How do I reset the WHOLE thing? ... Processing dropped files.
Amp'D Maxx Music Player - Fixya
Dec 18, 2015 | Audio Players & Recorders
02 grand cher. 55000 miles. 4.0 engine. intermiten problem. on start up RPM's go to 2000. stays there briefly, drops to 1500 briefly, then slowly drops to 1000, late goes to 800 to 900. jeep dealer...
buffalo man said engine doing what it should do. friendly neighborhood mechanic said it go 1250 RPM on start up, then drop to 700 to 800
found defective part outside throttle body. runs OK now
Oct 26, 2009 | Jeep Grand Cherokee Cars & Trucks
Sansa e260 says connected but device not recognized
The same thing happens with my camera and it is a problem with the usb cord.
You might want to buy a different one and try that
unfortunately I can't unless I buy the whole camera package :(
Jul 24, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 MP3 player
You Might Need a new battery or also try cleaning  the usb intreance of your sansa e260 with a Q-tip.
May 19, 2008 | SanDisk Sansa e260 MP3 Player
Downloading
Convert you *.cda CD files into MP3 extension files, then put them into as many subdirectories as there are disks to avoid overriding the number of cuts on a disk (typically no higher than 25), then
put them in directories marked 1 thru whatever number of disks there are, drag and drop the respective converted mp3s to the directory that corresponds to the CD disk. Then drag and drop the whole works to your playlist directory in your e260, and presto you've got the whole thing. The E260's included software will not do
this, but there should be some freeware around that will do it. Perhaps evern media player will do it. I don't know. I'm wary of any MS programs. They're monsters. The who drag and drop procedure is done in Windows Explorer, the file manager of XP
and, I think, vista too.
Mike Rice
mike872@centurytel.net
Apr 20, 2008 | SanDisk Sansa e250 MP3 Player
Problem with sansa e260
that happens to me too. i think the problem is that your computer can't like, sense that it's plugged in, so your battery's dying out, and the computer wont charge it
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa USB and Charger Problem
hi ya, ok one of the solution is checking out the trouble of litium battery, i guess has been out of base, i had the same siptom with sansa e250r 2-g, put in right the battery. In back of sansa there are 4 screws that u have to loose it
Aug 09, 2007 | SanDisk Sansa e260 MP3 Player
Please help me!!! im desperate!!! sandisk sansa e260
if your sanas e260 does'n syncronize with your computer or say data base..., take the battery out and conect it with out the battery.
May 08, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
