My audio speakers are not working for my computer
  • 1 more comment
  • Anonymous Oct 25, 2008
    MY AUDIO SPEAKERS THAT CAME WITH MY PC ARE NOT WORKING
  • haastyle69 Nov 19, 2008
    rei have no sound i restarted pc with operating system disc now i have no sound will u please take over my pc and fix i dont know what i am doing
  • rickypr-16 Feb 23, 2009
    the speakers do not sounds
    Problem Solver:
  • 18 Answers
Check and re installed driver of your audioalso check your speaker audio input connction....
Posted on Apr 15, 2008
    Problem Solver:
  • 9 Answers
I have had the same problem with my speakers on my desktop athome. a freind of mine who is thankfully way more tech savvy toldme that is was most likely the driver, or that i had a registry errorand the sound card wasnt communicating with the speakers properly.
he told me to run a driver scan to make sure they were all in place.
this help link should fix your problem
http://www.windowsfilehelp.com/solution.php?sc=fy&kw=speakers&key=speaker+sound+not+working
good luck!
Posted on Mar 14, 2009
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
When i plug in the speakers no sound is coming out it doesn't work correctly i cant hear anything i'm playing.
Hi taceeg06,
Have you check all the Volume setting on you computer?
On the lower right side look for the computer Icon check if there is a red X on the speaker Icon, if there is then it can be that here is something wrong with the speaker driver or it does not detect the speakers.
If you do not see the speaker Icon then the Driver for the Audio card is not installed on the computer and you may need to re install that Audio Card Driver to be able to regain the audio from your Speakers.
Also the speakers should connect to the Green Audio Jack behind the computer, if it is then still no Audio you can try the Audio Jack in front of the computer as well to check the Audio Card in the Machine, if the front and back audio jacks do not detect nor produce sound when the speakers are connected then re installing the driver for the Audio card may work, unless during the installation an error shows that the there is no audio device detected then it means the Audio Card is busted.
Let us hope not since it is very seldom an Audio Card could go busted.
I hope this helps.
Have nice day,
mvincentc
Jun 12, 2011 | Insignia 2.0 Speaker System (2-Piece)
I purchased a new computer and after hooking everything up, everything works except I have no audio. I believe the speakers are internal to this monitor.
Double check that you have the speaker cable plugged into the proper jack (audio out - green) on the computer. Make sure that the audio hasn't been muted and that it is set for the correct output type (if you have a multi-channel audio option).
Try a standalone set of speakers to check if the audio driver for the on-board audio or sound card is working.
I hope this helps.
(I've found that the integrated speakers will fail before the monitor does. Since the integrated speakers are low-end and similar speakers are fairly cheap, get new speakers of a quality you like. Repairing the speakers isn't worth it.)
May 19, 2010 | AOC LM729 17" LCD Monitor
Reformatted Computer. No Sound.
Looks like you haven't installed your audio drivers.
Dec 27, 2009 | Logitech X-240 Computer Speakers
I just re-assemble my computer and speakers and my speakers is not working now. I am not sure if I have left a plug out. Should something be plugged into the 'Audio In" slot?
Audio in is an auxillary imput. Your speakers should be plugged into audio out. Check the power supply to your speakers. Enter Control Panel > System> and Device manager and make sure your audio drivers are working. Also enter Control Panel > Sound and Audio Devices and check the box that says "Place volume icon in the taskbar then open the volume control and make sure none of them are muted and that your volume levels are high. You can then click on the sounds tab and choose one of the sounds and hit the test button to check your speakers. Hope this helps. If all else fails check your speakers on someone else's computer.
Nov 19, 2009 | Philips MMS171 Computer Speakers
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
Speakers keep cutting out when they are plugged in and a high pitch squeal comes out of computer speaker
How many Audio ports do you have in the back of your computer? Also, what Audio DRIVERS do you have installed in your computer? If you have REALTEK audio drivers, it SHOULD automatically recognize the speakers are being plugged in and change that ports usage over to speaker output, but not all drivers do this. It could simply be that you're plugging them into the wrong port audio port if you have 4 - 6 back there, as some motherboards do. Try different audio plugs and see if that works for you.
Jul 06, 2009 | Logitech X-240 Computer Speakers
My computer is saying no audio device
Ok lets do like this
If you your mother board CD ,?  get play that and you will find an option for sound and audio devices , please reinstall that.
I hope it will work  .Please do reply..
Dec 21, 2007 | Sakar Adrenaline Computer Speakers
Computers & Internet Logo
515 people viewed this question
David Payne
David Payne
