Question about Saeco Trevi Automatica Cappuccino
Water size selection!
My Saeco Trevi Automatica does not let me select the volume for the water size. On full volume selected makes esspresso size only.
  • 515 Answers
Do you have a trim pot on your machine or just buttons?
Posted on Jul 11, 2008
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
Please could you tell me what the 3rd button (from the left), which has "drops" under it, is for on my Trevi Automatica?
As far as I remember, It should switch paranello stick on the right of the machine (milk steamer) from steam to hot water (for making tea for example) and back. Try pressing and turn the knob at the right side of the machine.
Mar 23, 2011 | Saeco Trevi Automatica Cappuccino
The water container releases too much water and it spills out the back and sides of the machine
Water container have a small valve which work with a small spring and o ring. You can remove the container over a sink unit fill with water and try to press with your finger to check if it block the water without pressing it and also check visual if their any dirt or scale blocking it from closing full or if the o ring is damages in any point.
In any case the valve work very simple the the spring force down the piston and o ring should block the water from ascape if any of thsi is dirty or damage or the loose then the water will leak.
You should also check the valve base on the machine body since their can be something that blocking the valve sit corectly on base so water can leak out of the piping arount the machine.
Good luck
Aug 15, 2010 | Saeco Trevi Automatica Cappuccino
How do I change the aqua filter in the Saeco Vienna Automatica machine?
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
Dec 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
How do you clean the inside of a saeco trevi
Run vinegar through it. Is this what you are asking?
Dec 26, 2008 | Saeco Trevi Automatica Cappuccino
Making Espresso shots... how does the macine do this? Not in man look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Blinking red light
When you prime the machine, can you get a full cup of water or just a half?
If you only get a half then you have to replace the "water turbine" in the machine.
Mar 04, 2008 | Saeco Trevi Automatica Cappuccino
Saeco Trevi Automatica Cappuccino Logo
117 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
