Question about Car Audio & Video
Wiring diagram for vs1100xr car alarm uniden - Car Audio & Video
2 Suggested Answers
SOURCE: uniden vs1100xr car alarm will
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Posted on Apr 18, 2009
Whats the brown wire in ignition
VW doesn't make their wiring diagrams available for free so I am unable to look this up.
May 18, 2016 | 1999 Volkswagen Beetle
Where is the fuse to the alarm for a 2003 gmc yukon
2003 GMC Yukon Car Security Wiring Diagram
www.modifiedlife.com/2003-gmc-yukon-car-security-wiring-diagram/
Whether your an expert GMC Yukon car alarm installer, GMC Yukon ... GMC Yukon, a 2003 GMC Yukon car alarm wiring diagram can save yourself a lot of time. .... Alex, double check ALL your fuses and make sure ALL your fuses are good.
How to Disable a Car Alarm - YouTube
? 2:41
https://www.youtube.com/watch?v=EKbjYlK4g0E
May 13, 2009 - Uploaded by ehowauto
In order to disable a car alarm, an individual will have to locate the horn that was put in and disconnect it, or ...
GMC out alarm fuse Questions & Answers - Fixya
www.fixya.com/tags/out_alarm_fuse/browse/gmc
If you have an alarm installed remove the in line fuse from the alarm and see if that ...Multiple issues with my 2003 GMC Yukon XL and hope someone can offer .
Jan 20, 2016 | GMC Cars & Trucks
Wiring diagram for TKA6 car alarm
Dont bother just put a crooklock on the steering wheel ,all these add on alarms give problems and fail as the circuits are junk chinese things for cheapness ,
Dec 06, 2014 | Cars & Trucks
Wiring diagram of alarm system for Myvi
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Nov 02, 2012 | Cars & Trucks
MY CAR WONT START BECAUSE IN AFTER MARKET ALARM. hOW DO i BYPASS THE ALARM TO START THE CAR
I've ran into this problem myself, if you're not confident with doing some wiring you probably should not be doing this. This will probably take 1 to 3 hours to do this. If you can get a wiring diagram that showed how the alarm was originally installed. If not find the alarm probably underneath the dashboard, the alarm wires will problem be smaller than a wiring that is in your car. When removing the alarm think of it as this way, someone cut into the middle of your wiring harness and put a alarm in. Would you need to do is remove the alarm and splice the cut wires back together. Instead of removing the alarm all at once try disconnecting one wire in a time and finding its mate. The wires or color coded. For example, black with an orange tracer. This would mean it's a black wire with an orange line on it. If you're not sure look at a wiring diagram splicing the wrong wires together could cause your car not to function properly or damage it. Before you start this make sure you disconnect the battery also. Good luck.
Jul 18, 2010 | 1998 Ford Mustang
Info on Aftermarket Generations Alarm AGA1201
The first link takes you to a good cheap place to buy this particular Aftermarket Remote System
The second two links offer diagramming and installation information. Hope this helps.
http://cgi.ebay.com/NEW-AGA1201-FM-Car-Alarm-Remote-Start-Keyless-Entry_W0QQitemZ230313882162QQcmdZViewItemQQptZCar_Alarms_Security?_trksid=p3286.m20.l1116
icon_bins.gif www.the12volt.com/ · Cached · Save Free vehicle wiring diagrams and technical information for car stereo, car alarm, electronics installers. Ohm's law, resistors, passive crossovers, subwoofer boxes, ... Free Vehicle Wiring, Relay Diagrams, ... ... icon_bins.gif www.vastbeyond.com/440.htm
Find Free Automotive Wiring Diagrams! ... Your Simple Source for Free Automotive Wiring Diagrams ... Free Automotive Wiring Diagrams.
Jan 07, 2009 | Chevrolet Cavalier Cars & Trucks
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
This procedure is:-
Sep 28, 2008 | Car Audio & Video
Car Audio & Video Logo
455 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
