Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
NO SOUND IN MY SHARP AQUOS LC-32D4U
I'M HAVING THE SAME PROBLEM WITH MY SHARP AQUOS.
.....NO SOUND !!!!
ANY SOLUTION FOR THIS LITTLE PROBLEM?
OR SIMPLY REPLACE IT !!!
  • Peter Thompson
    Peter Thompson May 11, 2010
    This will be the obvious, but are you sure you have not just hit the mute button on the remote.
    If you are sure, then what was happening leading up to the sound failing?
    Even if the sound has failed, there is no need to replace it (unless it's under warranty still)
    Just use an amplifier with surround speakers and a digital set top box.
SOURCE: Audio Problems with Sharp Aquos T. V.
I called Cox Communications and the technician told me to disconnect every cable or connection and turn the DVR and T.V. off. Cox ran a diagnostic check to make sure my DVR was reading proper info from their center. It was, and then I reconnected everyhing, cables, HDMI plugs, and finally turned the DVR on. It read Boot, and then, I waited for the time to show. When it did, I turn the T.V. on. It has worked great since then. No problems with sound or picture. Hope this helps someone.
Posted on Nov 22, 2007
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Posted on Nov 06, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
Wont turn on
seems like a power issue.
u should have the power checked out on the tv
Oct 02, 2008 | Sharp LC-32D4U 32 in. HD-Ready LCD...
How can I turn LCD-32d4u sharp to av without remote?
Press the power key. When the set comes on to Standby, press one of the channel Up or Down keys
Sep 07, 2014 | Avianne & Co Sharp LC-32D4U AQUOS 32-Inch...
My sharp LC-32D4U won't play audio with Apple TV is there an audio cable I can buy to fix this?
The good news is that you can likely make a simple change on the Apple TV to make it compatible with your existing TV's sound processor. Check out the following Apple support article for further assistance:
http://support.apple.com/kb/TS5150
Jan 02, 2014 | Televison & Video
I'm trying to connect external speakers to a Sharp Aquos LC-C3234U TV but not having any success. Can anyone help?
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
Oct 31, 2012 | Sharp Televison & Video
I am no longer getting sound from my Sharp LC-32D4U. Can you help?
Perhaps you forgot to set the HDMI sound on your Sharp TV.
On your Sharp remote, press:
1. MENU
2. OPTION
3. HDMI SETUP
4. AUDIO SELECT
Sep 04, 2010 | Sharp Televison & Video
I have a Sharp LC 32D4U TV and the sound is not working.
Try unplugging the power for 2 minutes and then replug/ turn it back on. This resets the TV's motherboard.
Jan 12, 2009 | Sharp Aquos LC-32D40U Television
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Three LC-32D4u Aquos TV's
There is a known problem wth the firware for these sets, what you can do is call Sharp at 1-800-Be-Sharp at explain the problem, they may send you a SD card with the upgraded firmware and the instructions on how to install it
Jan 25, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
156 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
