VG 800 The front led is blinking green and will not turn off. No picture on screen.
  • 3 Answers
Try this troubleshooting, first is the vga cable is connected properly to the vga port of the cpu, second check if the voltage rating of the outlet is 220v depending on the monitor rating some unit work with 110v. third if it still does'nt work try to transfer the monitor to other cpu (if you have one) may be the video port/adapter is damage.
Posted on Apr 15, 2008
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Nov 24, 2011 | Mitsubishi WD-60737 TV
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
I have a Panasonic th-42pw5 plasma screen
most likely it is the buffer boards and the z sus
Feb 12, 2018 | Panasonic Televison & Video
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
MAG MS776 17'' LCD, black screen problem
Call to Our Technical Support Number 1-800-204-4427 for PC Screen Problems and Get Instant Resolution of Your Query.
Apr 15, 2017 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
