Question about Eureka WhirlWind Litespeed 5844 Upright Vacuum
Belts keep breaking
Hi, I have a Eureka WhirlWind LiteSpeed. I love this vacuum and really don't want to abandon it for a new one. When I changed the belt after it broke, the new one broke almost immediately. I put it off to a fluke and installed the 2nd belt (2 in a pack). The 2nd belt worked fine for awhile, then broke. I bought more belts, same exact thing would happen. First belt breaks almost immediately, 2nd will work a little longer. Tonight, however, both belts, both brand new out of the pack broke as soon as I started vacuuming. I am meticulous about cleaning the rollers, changing the filters, and emptying the cannister.
Please help me. What could this be?
  • Mariah Lane Oct 10, 2008
    I never did find out what the problem was. But I found a good solution. Instead of using the recommended belt size, I use one slightly longer and thinner. Works great on keeping the belt from breaking, every now and then it does come off though. I just open it up, put it back on, and keep vacuuming. I've never seen another vacuum with the power and suction as this one, so I'm willing to do this for a little longer.
    Thanks for the help.
    President:
  • 1,673 Answers
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Posted on Apr 15, 2008
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
I live at zip code 24060 and I need a new belt for my Eureka Whirlwind. Where can buy this?
You can get them at Walmart.
Look on the nameplate and it will tell you which belt too buy
(Probably a "U" belt)
Sep 09, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
The bristles aren't rotating. Is there an easy solution to this?
The belt probably broke. Simply purchase another belt and replace. These belts are made for much stress, and if you've had the vacuum for even a month, they can easily break.
It may also have slipped off the motor shaft, causing the brush to spin freely.
Aug 22, 2010 | Eureka Whirlwind LiteSpeed 5843 Upright...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
The vacuum roller won't turn but the belt is fine Eureka Whirlwind Litespeed
The belt may look fine but it's probably stretched out. Rubber belts are usually good for about 1 year. The tension of the belt is what allows it to turn under the strain of the carpet. Make sure the brushroll spins freely when held out of the machine. Eureka brushrolls are prone to melt down on the end caps. If that has happened you will need a new one.
May 01, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
My Eureka Whirlwind vacuum on-off switch won't turn off
the power switch is bad. go to your local hardware store and buy a new power switch and replace it.
Mar 23, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Mar 22, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Eureka WhirlWind Litespeed 5844 Upright Vacuum Logo
342 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
Roger Potts
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
