Question about RCA Televison & Video
Rca model # hd52w67yx39 ser # f502c10f8
On screen menu keeps coming on by itself and volume goes up and down by itself also. unit is a 2005 model
  • 1030 Answers
SOURCE: tv problem
i have encounterd this problem a few times in the shop.. i resolved the issue by replaceing the front control panel pcb. i had one instance of a bad ir sensor causing the problem
Posted on Jan 04, 2008
  • 184 Answers
SOURCE: MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Posted on Feb 17, 2009
  • 4234 Answers
SOURCE: RCA D52W20 52 in. Rear Projection -HELP!!!!
As stated by TVtechlady, it is possible for the buttons to be stuck. With the set unplugged, try pushing each of the buttons one at a time. You should be able to feel the button engage. If one of them does not, then that is the likely bad one. Also, if there is some dirt caught between the button and the hole, it can create enough friction to prevent the button from returning to the "OFF" position on its own. Spray some compresed air around the buttons and work them a few times by hand. Plug hte set back in and try again,
It is also possible that the 5V supply inside the set is having a problem and is comfusing the set. Try working the buttons first and update this with the results.
Dan
Posted on Oct 07, 2009
Testimonial: "Thank you for the response, I will try it out and get back Thanks again"
Slinteriors
  • 8617 Answers
SOURCE: The menu on the RCA R52WH74 keeps flashing and tv
You will need to replace the signal board very common problem. You can get a replacement signal board from www.tvrepairworld.com
Posted on Dec 01, 2009
ladywinn
  • 5138 Answers
SOURCE: RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Posted on Jan 18, 2010
My tv starts scrolling through video modes,and the menu screen constantly flashes on and off and i turn up the volume and it goes back down by itself,any thoughts how to stop this would be very helpful...
Thats caused by the Small signal board. which is the green board on the right side with all the inputs on it. Thats a very famous issue for RCA rear projection models.
Nov 07, 2012 | RCA HD52W140 52" Rear Projection...
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Small signal board for RCA HD52W59
Thats caused by the small signal board located on the right side of the set ( Green board with the RCA plug inputs on it. Very common issue with that chassis. The board will have a barcode sticker with an as222 number. You can get replacement boards and any part needed for that model from www.tvrepairworld.com
Jan 28, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 tv
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Rca sound and menu problems
Here at my shop we see this problem with these rca sets. The processor is seeing a command from the keyboard or the ir sensor. The most likely cause is a faulty keyboard cuircit board. And replacing is the best coarse of action. To make sure its the problem I remove the keyboard cuicit board and see if the problem goes away. I just use the remote to control the tv, u can also do this until the part arives To get the part you need to know the entire model number. It will be on the sticker in the back in small letters hd52w56yx1 or yx30 or something to that extint. i get most of my rca parts from union electroncs or just let me know and i can look up the part number for you
Nov 12, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA projection TV
are buton on remote sticking or on tv it self clean controler tap on button
Oct 07, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 27F520T TV
Models: 24V511T, 24V510T, 27V512T, 27V513T, 27V520T, 27F520T, 27F50T, and 27F634T
TOPIC: Set comes on by itself
Symptom: When the set is first plugged in or after a power interruption the set comes on
Cause: Set was not taken out of factory mode, or has returned to factory mode
Cure: In the service menu go to setting FAC07, then change the value of OPTM2 to “00”
To enter the service mode simultaneously press “Volume Down” on the front panel and “Info” on
the remote control.
Use the original TV remote for the instrument.
Press “7” on the remote to enter factory menu 07. Use the channel down button to scroll down to
OPTM2, then use the volume buttons to set the value to 00. Press the “Sound” button on the
remote to exit the factory mode. DO NOT turn the set off until the screen displays “OK”.
Sep 12, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
