The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
