Question about Lexmark X7350 All-In-One InkJet Printer
Installing ink cartridge into a modle 5400 series
  • tazzme Jul 13, 2008
    I purchased photo ink cartridge, but the computer tells me that is it a improper ribbon and I don't know what to do
  • Cnythia Miller May 11, 2010
    Is this A Hellet Packard product?
    Problem Solver:
  • 18 Answers
Try to open this link ..http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00846503&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
tnx en good day..
Posted on Apr 15, 2008
My printer is a lexmark X7350 and I purchased the photo printer ink cartridge and the printer tells me a improper cartridge. I dont know what to do
Posted on Jul 13, 2008
Need to know size of ink caridiage for x5400 printer all in one
Search Lexmark X5400 toner or ink
Same cartridge all over the world. Plus there are options for new or refurbished,
https://www.inkworldwide.co.uk/lexmark_x5400_series
http://www.inkfarm.com/Lexmark-5400/ink-cartridge
http://www.hottoner.com.au/Cartridge/Lexmark/Ink/All-In-One-Supplies/X5400.html
Nov 12, 2012 | Lexmark International Lexmark X5400 Series
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
I have a Epson CX 5400 printer.I have installed all new ink cartridges.The printer continues to say that I need to insatll the yellow ink cartridge,but I already have installed the yellow one.What should I...
You did pull the tape off the nozzle, correct???
Is there a tab on your printer software that says INSTALL NEW INK or similar?
Open the control panel then click on the icon that represents your printer to find the tab(s) I am speaking about.
I hope you found this helpful
a
Sep 23, 2009 | Epson Stylus CX5400 All-In-One InkJet...
X5470 ink cartridge
Download the publications for your printer series 5400.
Feb 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Ink
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 all in one
It is observed in branded printer not only lexmark also with HP printers yoou get this same problem.
It is always recomended to use genuine cartridges rather than refilled or any other brand ink cartridges.
As for HP cartridges they are all made under six sigma process where it is very rare you get a ink cartridge issue.
thats why HP Gives 18 months of replacement warranty on its cartridges
The same applies to Lexmark printers aswell
Make a habit of usig Genuine cartridges which will give value for your money.
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X7350 All-In-One InkJet Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
