Guys- I'm in 'hot water' and this ain't no pun.. Bought a house in Lakewood, CO and my wife's shower has a Delta Monitor 1700 Series shower faucet. Do you know if it is pressure balanced? I can't even make coffee in the morning without her getting a cold shower let alone flushing a toilet. Seems like every water faucet that reduces the cold water pressure gives her a cold shower. Should I trash the fixture? Thanks Frank Scheubel
  • 329 Answers
Dont trash it! i suggest you should check all the setting and the procedures in the manual, check if first before you trash the item.
Posted on Apr 15, 2008
Shower force
Are you wanting to change/switch the hot and cold range of the shower or the temperature max and min? As for the range, the Monitor pressure balance valve may be having build up or problems. This valve controls the mixture of hot and cold water. To fix this, you will need to turn off the water supply, take the pipes apart and clean out the valve (I would recommend a professional). As for the max and min, you may just need to check the water heater pressure in your house. It may not be the faucet at all.
Elisa Jed '
Feb 18, 2014 | Delta Home
Delta Lahara Monitor 14 series faucet
no call delta 1-800 345-delta see if they have a reverse cartridge
Nov 01, 2012 | Delta Home
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
Adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
May 05, 2010 | Delta Home
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
How to turn on shower head of Delta monitor
I'm at my cousin's place and he has a delta monitor. Similar to what you guys are talking about.
To turn on the shower, I had to pull down on the faucet head, not the shower head.
To turn off the shower, I had to push the faucet head back up.
Hope this helps anybody out.
Mar 24, 2009 | Delta T13420 Chrome Classic Single Handle...
I have a Delta Series 1400 faucet in the tub/shower. The handle turns left and right for Hot & cold, but I do not know how to adjust total volumne. Is the round know supposed to pull out? It does not...
hi roger,
Sorry Delta 1300 and 1400 series valves do not have a volume control. Kinda odd but that is how they are made.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
My shower has a delta monitor single faucet. And the flow has diminished so much that I am only getting few drops. The house has a lot of water pressure. What can I do?
Sounds like you have lost pressure on one side of the valve. ( either hot or cold ) Or the cartridge has gone bad. If you have hard water if probably is the cartridge. There are a couple of different series for your style of faucet.
The reason why you only get a few drops is the cartridge is pressure balancing. It is a safety device which prevents scalding if one side of the supply shuts down.
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
