Question about Jl Audio 13W7 Car Subwoofer
Wireing problem i have the 13w7 with a 2ohm 1600 watt amp how is the best way to hook up duel voice coil for the most power
You should run the voice coils in series so you would load your amp with 3 ohms.
Posted on Jun 11, 2008
On a lanzar 535n 5 channel 3200 watt amp what is the best way to hook up 2 lanzar max 12 inch duel voice coil subwoofers
If your amp allows it hook the the sub's to the first two channels but bridge it and only run it on 2ohms so you don't blow your sub's
May 29, 2015 | Lanzar Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I have a 2500 watt legacy ice amp and im tryin to hook it up to two 900 watt rms soundstreams daul voice coils whats the best way
If you amp is 1 ohm stable you can run + to +, - to - on each voice coil. Wire them into the box. Run +'s to +'s on amp, - to - on amp
Other wise. If it is a 2 ohm stable amp, you run two 4 ohm dual voice coils to the amp + -, + -
If the subwoofers are 2 ohm, run + - on only one voice coil to the box for each and run + -, +- for 2 ohm load on amp or + - bridged for 1 ohm load.
I hope that makes sense.
Dec 03, 2009 | Legacy Audio ICE LA798 Car Audio Amplifier
Speaker or amp?
your running too low impedence, and yes its cuz of your sub wiring. How to wire it depends if its 2ohm dual voice coil, or 4ohm dual voice coil, so i'll explain both. O.K. first of all i hope its 4 ohm so you can get max power from your sub. If it is 4 ohm dual voice coil connect + to +, and - to - on your speaker, then to connect it to your amp, splice a wire into the wire running from + to + and connect it to your amp's + terminal. Do the same with your - wire. If its a 2 ohm dual voice coil, connect the + from one set of terminals on the speaker, to the - on the other terminal. Then to connect it to the amp, plug a wire from the open + terminal on the speaker and connect it to the + plug on the amp, and do, connect the empty - to the - on the amp. Good luck and if you have any questions don't hesitate to ask...
Sep 20, 2009 | Car Audio & Video
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Visonik V12D4
i would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Jun 18, 2009 | Earthquake Sound PH800W.2 Car Audio...
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Kicker l7
hook them up parellel for 1ohm load
Nov 23, 2008 | Car Audio & Video
Amp getting really hot
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
Subs
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Feb 25, 2008 | Car Audio & Video
Jl Audio 13W7 Car Subwoofer Logo
134 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
