Ihave a emachines modelT2792 and have een told the mother board is no good as well as the power supplycan i get another mother board for this computer or is it too old to fix it is about 2 years old
  • Barbara Ponce
    Barbara Ponce Aug 15, 2008
    my computer shutdown with not reason and restar again,some times not star for hours
    Genius:
  • 1,226 Answers
when all some other parts are good maybe you can replace the the mother board and the power supply.
you should find motherboard replacement that will fit to your processor and Memory.
if the memory , processor, hard drive are good, then you can contact your vendor if the have replacement(mother board) and power supply.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 15, 2008
  • Emelio Navaja
    Emelio Navaja Apr 15, 2008
    Or you can call the technical support here:
    Telephone Technical Support
    Customer care representatives are available 5 AM to 12 midnight PT seven days a week.
    United States 408-273-0888*
    Canada 604-637-1419*
I have emachine t seris t2862 desktop and I donnot know how to connect power swich in mother board please help me
On the motherboard there will be a small set of connectors marked FPANEL, next to each of these will be a set of letters (usually PW, RES, HDD, MSG) and an earth pin, From the power switch you will see a two wire set normally black and white ending in a connector, this connects to the PW pins on the FPANEL
Jan 06, 2011 | E-Machines eMachines Refurbished EMA...
Power button on emachine t3882 have come loose
look on the mother board,, with it on its side,, power button facing you.. On the Mobo look at the bottom left were all the other small plugs are. that come out of the face of the computer.. it should be marked PWB or SW
Mar 01, 2010 | E-Machines eMachines Desktop PC
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Power supply for Emachine
WhoDoctorK9 is right. You'll need the model number of the pc to pull up any schematics of the board. This is, however, how you solve this problem. Just google your model number and try to find a schematic of the board.
If you can't find the schematic, the board should be marked with some sort of 'pwr' blah blah white lettering. It's hit & miss, but you can find the connection without visual aid by dimensions of the plugs and the obscure little identifiers on the board itself.
Good luck and may the force be with you. :P
Mar 27, 2009 | E-Machines eMachines Desktop PC
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
T2984 won't power up
I've re[lace alot of bad eMacines power supplies. Nearly all of them took out the video chip on the mother baord, rendering it useless.
Mar 23, 2009 | E-Machines eMachines Refurbished EMA...
NO POWER TO THE MOTHER BOARD OF MY EMACHINE
The Wires goes on the motherboard, check your motherboard manual for reference
Mar 17, 2009 | E-Machines eMachines T3830 PC Desktop
Desktop
most likely your guess is correct and if a beep sound is not availabe (Power good signal) than its 100% power supply problem.
Apr 26, 2008 | E-Machines eMachines Desktop PC
Emachine Desk PC T6216
Sorry, it doesn't seem like it is a problem that can be solved here. Sounds like time to go to the repair shop.
Dec 28, 2007 | E-Machines eMachines Desktop PC
Emachine T4060 power supply
I have to assume you mean
Will the cooling fans run if it is still powered by mother board and disconencted from the mount ,such as processor or chipset ??
Yes it would , but is a very dangerous thing to do ,as it could easily short against anything within the case
Be more specific with your problem maybe someone can help you better
Nov 14, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
