Port forwarding need to open port 63415 on 71.10.246.82
  • David Joseph May 11, 2010
    hi there,
    need the type of modem/router u are using to be able to help u ...
  • Russell Alexander May 11, 2010
    What router are you using?
    Scholar:
  • 75 Answers
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Posted on May 01, 2008
Why can't I print on cloud print with my canon inkjet mp830. It keeps saying "printer offline"
Hi, you may find that opening port 5222 in your router settings corrects this for you. This is due to Google Cloud Print (GCP) needing to poll your printer, if the port is not open then GCP will not get a response from your printer, therefore will show it as offline.
It is also possible that your firewall is blocking communications so you would need to open the same port (5222) in your firewall / antivirus software.
Warning: Ports are often closed on a router to help prevent unauthorized access to your home network. Opening any additional ports on your router may decrease the overall security of your network.
  1. To use port forwarding first determine the local IP address of the computer or device you are forwarding the port to.
  2. Open your router configuration / settings menu.
  3. Once in the router configuration locate the port forwarding settings, often in a section such as Applications & Gaming or Port forwarding. I would suggest that if you are having difficulties with this to refer to your router documentation or call their support line.
  4. You will only need to open port 5222.
  5. Give your new rule a name that you will recognise.
  6. Next enter the port number 5222, if you are asked for Externet and Internet enter 5222 in both.
  7. The protocol is TCP.
  8. Next is the IP address of the computer.
  9. Don't forget to check the enabled box if there is one and save changes.
If you have any issues with this I would suggest Port Forward web site where specific instructions should be available for your router.
Tom
Jan 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
I want to know how to open my ports and forward them pls
Its simple to open or forward a port. Please go to this website, www.portforward.com and look for Common Ports tab. That will tell how to open the ports.
Oct 22, 2009 | Zyxel P660HW-D1 Router
Nat setting
Two things are important for opening NAT:
  1. You have to give your computer a static IP address, so the forwarding process can find the right machine to forward to. If you don't know how to do that, you can find a guide here.
  2. You need the specific port numbers you want to forward. Of course you can just open ALL ports, but you would expose your computer to port scanning, which is a huge security risk. (Think of your car door that has a keypad for unlocking. Now you say "press any number between 1 and 65535 and the door will open" - You don't want to do that, right?)
Look at this page, which lists many applications and gives you detailed step-by-step instructions how to set up port forwarding on this router. If your software is not mentioned, you still can use the default guide and just replace the port numbers with the one(s) you need to forward.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 26, 2009 | Arris SURFboard SBG900 Wireless Router...
On my echolink progtam it says to use port 5198 or 5199, how do I do it?
access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
For belkin router http://192.168.15.1
type user nams as "admin" and password as "admin" or blank or "password"
Then go to NAT and prot forwarding .
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
then go to NAT
Aug 31, 2009 | Computers & Internet
I cant get a port to open an it needs to be forwarded how can i do this i have a linsys router B i have tryd to forward it like it said but it still says its closed i already turnd the firewall off an...
You should set static IP address on the device first before doing the port forwarding. And the port needs to be specific for certain applications. Go to www.portforward.com for helpful tips about the exact ports to be opened.
Jun 29, 2009 | Computers & Internet
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
http://portforward.com/
May 10, 2009 | Computers & Internet
Port Forwarding on Bigpond 2071a
you need to go into the modem settings and open a port.You set a number 32599 and apply works perfect for me and then got into preferences at utorrent and set the 32599 number and apply now check to see if your port is open.
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
633 people viewed this question
David Payne
David Payne
