Question about Maytag SAV2555A Top Load Washer
Maytag SAV2555 will not spin
Hi again i got the helix nut and put it on it still does not work when i turn the belt by hand it turns for a moment then it clicks and starts over will not turn the drum. couls it be the pully? or the trany. if you think it is the trany pully how to take it out i have tried it wont come out, does the hole ajitater have to come out? thanks agin
    President:
  • Maytag Master
  • 2,651 Answers
It does( withiut looking at it myself), sound like the pulley/helix are just slipping past eachother and not engaging one anoher, does the sloped side of the pulley(wehre it meshes with the helix appear to be rounded over???) thats really the only reason i could see to replace the pulley.. for get trying oto spin the belt can you grab hold of the p[uley and try spinning it directly????. rfeason i askl is that in order to replace the pulley, youll need to rease th springs around the bottom of tub, and remove the entire unit from the cabinet, after removing unit, turn unit upside down, you need to remove the motor,, then unbolt the 3 white legs form the outer tub, and remove the 3 brake pads bolted to underneath uint with 3/8 nuts, the stansion then will lifht up giving you room to remove the pulley. awful alot of work if not needed,
Posted on Apr 17, 2008
  • cthomas24780 May 26, 2011
    I have the same issue. I pulled the front cover off and it looks like the white hard plastic helix is not lineing up with shaft it is supposed to. Could the bolt for the helix have come loose or could there be a need to replace the helix,bolt , and washer only
  • Ron Coons
    Ron Coons May 26, 2011
    well, its been threee years since i posted this repair, and i believe we are jumpin into the "quoted repair" a few steps into the correspondance. That being said, with the cover removed your looking at the "helix and pulley(belt is wrapped around)" mounted on bottom most portion of machine... the helix and pulley are actually complete opposite cut peices of angled plastic, which when turned one way( you can spin the pulley by hand) the helix and pulley simply catch each other adn spin the ajitator.. however when turned the opposite way the helix actually rides the "ramp of plastic pulley" causing the pulley to slightly rise upwards, releasing the brake plate inturn spinning the entire inner drum(engaging spin cycle).
The turbobrush for my cleanview helix 22c1 is not working
It's probably either just dirty, or the belt is broken. If it's dirty, you can just take the cover off (two Phillips head screws on the bottom) and clean everything off the brush.
If the belt is broken, you can tell by turning the large gear at the back of the brush -- if the brush turns when you spin the gear, the belt isn't broken -- then you'll need to replace it. You can buy a new belt online, or you can buy a replacement Turbo Brush directly from Bissell ($24.99).
Hope that helps!
Jan 10, 2011 | Bissell CleanView Helix 22C1 Bagged...
My bissell helix cleanview vacuums brush doesn't spin
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
The spin cycle is not continually spinning and removing the water from the clothes
The motor has 2 direction in turning. one for the Helix to make agitation. The other for the belt turns the pulley to make spins. However, the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Spin does not work new belt installed when spin starts tumbler not turning belt smoking thank you Douglas. model# sav205daww maytag.
Can you turn the drum by hand ?, if not then the bearings are siezing up
If you can , when the belt was fitted was it tensioned so that there was about half an inch of play on the longest side of the belt
Jun 17, 2009 | Maytag Washing Machines
Maytag washer sav2555
the pulley will not remove very easily , it wold require removine the milk stool, motor and some other parts, not the easiest hing to do especially if not needed, the helix you removed, take a look at it , the sloped ends of it should create a pretty sharp angle, then a 90degree drop off, the slopes om the pulley should be the same, they should not apppear to be rounded off,helix is probly 10 bucks if needed and if its at the helix that you see the "slipping" and "clicking noise, before condeming the tranny i would start with tthe helix, if after re-installing it it still clicks up and over pully perhaps try adding another spacer under the bolt before tightening. the idea behind the pulley and helix is that depending on rotation of the transissiion, the helix "pushes against" the pulley adn spreads the brake plate, releasing the brake allowing the tub tospin freely
Apr 06, 2008 | Maytag SAV2555A Top Load Washer
SAV2555A Top Load wont spin
im including this link for visual, Idont think this is your issue, but , you may be experencing an issue with the pulley / helix(bottom white). i would try removing and replacin the helix if appears worn(the top of the angular plastic gets rounded and allows the pulley to POP passed it. plus its only 1 bolt below holding it on, in order to replce the pulley youre gonna need to dismantle quite a bit of this machine
http://www.youtube.com/watch?v=IwOU0lc3dwU&feature=related
Apr 02, 2008 | Maytag SAV2555A Top Load Washer
Wont spin and makes a noise
def needs a pully to add tension in order to spin. reconnect adn watch what it does. where does noise appear to come from??? sometimes the lower most "helix" strips out on machine and sounds as if theres amototr boat in you machine.Its the bottom most item on the centraal shaft of the transmission held o by a 1/2 bolt. if either that or the pulley above it strip it wont dissengage the brake assy and will "motor boat" with no action from transmission
Maytag SAV2555A Top Load Washer Logo
166 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
