Question about Loewe Articos 55 55" Rear Projection Television
Screen removal Dirt on the inside of the screen on my ARTICOS 55. Can anyone tell me how to remove the screen and clean inside glass. Thanks so much Can e mail reply to: dpetrenko@yahoo.com
  • Anonymous May 05, 2008
    I have this problem too, can anyone help me too? Thanks
  • dpetrenko826 Nov 20, 2008
    Thank you for the reply ELOBYAN. Do the 2 screws you mention have to come out completely. I have loosened them to a point where they do not want to turn out anymore, but the screen will not loosen at all. Should I pull out where the screws are located.  I have a Loewes service manual but it does not cover the screen removal just the circuitry and part list. I appreciate your help and thank you again.
    Problem Solver:
  • 15 Answers
A 2mm Allan Key either side 6 inches up from bottom of glass filter. Loosen then pull out from bottom then lift up to release the top and lift off. If the dust is still visible you can remove the next screen to access the diffusers and wipe with a dry cloth. Make sure you take note of the position of the light diffusers when reassembling.
Posted on Jul 29, 2008
Monitor cleaning & hard glass protective layer removal
Of all the LCD/LED monitors I have used, I have not seen one that has a removable glass face.
Nov 10, 2013 | AOC International 23" Wide Lcd 1920x1080...
Why my samsung s3653w is very hard to touch...tnx
If you mean that your Samsung s2653w touch screen is not touch sensitive anymore, you need to clean your screen surface on a regular basis with a soft glass cleaner to remove dirt and finger 'oil' residues. Using a very light mist of eyewear/glass cleaner will help remove dirt and oil.
Hope it works for you!
Sep 24, 2011 | Cell Phones
I have just replaced the lamp in my Lowew Articos 55 HD DLP Rear Projection TV. This has improved the contrast and colour levels BUT it still has a slight blurr to the images on the screen which it never...
It is critical thet you replace the cooling fans! The imagers will be damaged if you don't. The focus issue is possibly contaminated a lens, dust or vapour.
Feb 11, 2011 | Loewe Articos 55 55" Rear Projection...
I have a Loewe Articos 55 HD, when we turn it on it makes a consistent loud buzzing noise. We spoke to a Loewe tech over the phone and he said that it would cost in excess of $2500 to fix - which seemed a...
replace the color wheel and remove the fan blowing on the engine, its forceing dust into the wheel area, the wheel will last about 14-18 months, removeing the fan will extended life 2-4 years, there will be no heat issues with the fan removed, some models or later production runs will not have this fan
Jan 19, 2010 | Loewe Articos 55 55" Rear Projection...
Looks like I have a couple of flys on the inside of the screen
Dont even think of removing the screen.....virtually impossible to reinstall. If you must clean...clean the picture tubes. Blow the dust off the lenses with air spray, then spray a lint free cloth with a lcd, plasma cleaner. Try not to use windex. [leaves a film on plastic lens] . Now pay close attention because the mirror you try to clean is a reflective plastic sheet that can tear easily. Lightly brush a new feather duster on this. Now you can only do this by removing the lower back cover [a hard cardboard material] and dislocate your elbo to clean . You can clean the inside of screen with the feather duster, donot use a cleaner inside the screen or mirror. Relocate the old elbo and replce the lower back cover.
Aug 25, 2009 | Philips 55PW9363 55" Rear Projection...
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
Outer screen gouged on mitsubishi vs-55609
How were you able to remove the plexi glass screen? I have the same problem, but I don't know how to remove it!
Jan 17, 2009 | Mitsubishi VS-55609 55" Rear Projection...
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Loewe Articos 55 55" Rear Projection Television Logo
184 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
