Question about Toshiba Tecra 8100 Pentium III, 850 MHz (  p000311140) Processor
Toshiba Tecra 8100 PIII laptop not booting
My toshiba tecra laptop is not booting. After switch on it flickers for a second and then makes a beep sound and shuts down.
Also my laptop screen display is not coming at all.
Please let me know what could be the problem.
I also have a tecra 8100 and my machine developed this exact problem. After much work, I finally figured out that it was a problem with the memory apparatus that holds the memory in place after it is installed. The memory modules are held in place by a cheap little plastic clasp. This clasp was no longer holding the memory far enough down in place and was causing an error when my machine tried to POST. As soon as I wedged something between the RAM and the access panel on the back(thus pressing the memory farther down in place), the machine worked fine from then onward. This is only a possible solution, don't take it as gospel. It's only one man's experience with his laptop.
Posted on Jun 28, 2009
  • 474 Answers
It could be a hard ware isuse. Try this.
If you have extra memory or removable Ram ( usually located on the bottom under a panel) Try removing it and starting it, with the ram removed. Then try putting it back in and starting it. If it works, it may be bad memory or it just needed to be reseated. Do this also with the cd drive and wireless card if it is removeable.
also try this with the battery, plug it in and remove the battery and see if it starts.
alot of laptops, like computers will not boot if there is a hardware issue.
The Beeping is a code. The number of beeps and how it beeps usually indicates an issue.
you could look the beep codes up on the toshiba website is the support center.
Good luck.
Posted on Apr 15, 2008
,toshiba tecra 8100
Oh..that one is hard to do specially to novice. I would suggest not to do it. It would be hard for you to dismantle your laptop bit by bit and it is very risky. You might it end up damaging your laptop. Take it to a qualified technician to get it done. okay..:-)
Dec 15, 2009 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Toshiba tekra 8100 on off knapp var finns den ?
> on off button where finds it?
The ON/OFF could a switch that "slides" about 50 mm,
or it could be a button with an 'I" inside a "circle".
The pictures at:
do not show any "button" on/near the keyboard.
The picture:
does not show any button on the back.
So, look for a "slider" or a "button" on the side(s) of the case.
Nov 25, 2009 | Toshiba Tecra 8100 (p000279550) Keyboard
Power on
what about power adapeter is it working fine....
Sep 05, 2008 | Toshiba Tecra 8100 Notebook
Tecra notebook
do you even see the toshiba logo on boot up ?
May 13, 2008 | Toshiba Tecra 8100 Notebook
Toshiba tecra laptop
Lee : what information are you loosing ?
Guest make sure your RAM is tightly secure. I had same problem. had to push my RAM in on boot-up.
Apr 17, 2008 | Toshiba Tecra 8100 Notebook
Drivers for Toshiba Tecra 8100
  • You should goto toshiba make registration of your product and download drviers which you want.
  • Or click here, select your model number and make download.
Gud Luck
CPU Upgrade
You pulled the processor out of your laptop ... that was a brave move ... generally laptop boards are fully integrated so there is very few options on changing the processor ... also because of the extreme heating conditions the heat sink bonding is very critical ... make sure you replace this properly or you will have overheating issues in the future ...
Mar 30, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Dead machine
you need to replace the memory stick it has given up on you !
Mar 22, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
Mar 19, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Tecra 8100 Pentium III, 850 MHz (  p000311140) Processor Logo
483 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
