Question about Panasonic CT-36D31 36" TV
PANASONIC CT-36D31 T.V. GOES OFF ON ITS OWN AND COMES BACK ON BY ITSELF 10 MINUTES LATER
  • Anonymous Nov 18, 2008
    TV goes off by itself and comes back on in 5 to 10 minutes.
  • 70 Answers
Check for dry joints around vertical chip, also dry joints in the horizontal stage will cause this also
Posted on Jul 07, 2008
No sound no picture high pitch sound
LOT [Line Output Transformer] fault. Check the horizontal scan output transistor too. If it is damaged, this kind of fault can occur. Anyway, the fault is related to its horizontal scan output section circuit. Check it. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Panasonic CT-36D31 36" TV
Panasonic CT-36D31E Television
Seems to me that the technician messed up something on the power board when he repaired the horizontal amp.. I would check for faulty solders, or components first. However, if you do not have prior experience, I would recommend getting a technician to do this, as it is very dangerous to open up a TV.
You could try a hard reset first and see if that helps: Unplug TV from power source and cables for about 2-3 hours and try again...
Oct 30, 2008 | Panasonic CT-36D31 36" TV
Lost sound while watching TV on cable. Checked all remotes, nothing helps. TV does have sound for VCR playback. What is the problem?
Likely the tuner in the set which aside from signal also processes audio---also if the set has a headphone jack take a look at that as it could cause this---small but some chance.
My bet is tuner
Nov 08, 2012 | Panasonic CT-36D31 36" TV
No sounds at all
Check the speaker maybe are damaged
Jun 26, 2012 | Panasonic CT-36D31 36" TV
NEED A PART NO. FOR ZENER DIODE D830
It is an easy to get component, All zener diodes will have a breakdown vltage, and it will be marked on it body. Read it, and buy a new one from any electronic spare part selling shops.
May 12, 2012 | Panasonic CT-36D31 36" TV
Hi, i need a replacement for diode number TVSSR2KLV1 for use in Panasonic 27' colour TV. Please help..
It looks like tou can sub this with B0ZAZ0000045 MCMelectronics.com has them for less than $3.00, but there will be shipping of course. They have many other parts and supplies which you might purchase at the same time rather than pay for shipping just one small part.
Nov 18, 2009 | Panasonic CT-36D31 36" TV
My tv turns on properly but after a few minutes it goes blank
you are having a heat related issue and the component or parts are failing. using a hair dryer blowing into back of set will make it black out and a portable fan should cool it enough to come back on. unless you know a good cheap tech, repairs are costly. i left the business when t.v' s became disposable.
Sep 21, 2009 | Panasonic CT-32D10 TV
Panasonic CT-32G13W shuts on and off by itself
Since the "bang" seems to fix it albeit temporarily, the problem is likely to be bad solder connections. If you can solder, resolder any connections on the board that appear grainy or have rings and update this with the results.
Dan
Oct 02, 2008 | Televison & Video
TV Shut off will not turn back on
the vertical i.c. is shorted, replace it.
Dec 20, 2007 | Panasonic CT-36D31 36" TV
Panasonic CT-36D31 36" TV Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
