Question about Carrier Heating & Cooling
I have a carrier furnace that I am working on and I do not have a schematic and the problem is I think I have a bad circuit board but I cannot prove it. the model is a 58SS080-BC The igniter will not light the pilot or even start sparking as long as the wire to the ignitor is plugged where it belongs on the gas valve as soon as you remove the wire the ignitor begins to spark.
3 Suggested Answers
  • 182 Answers
SOURCE: Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Posted on Oct 18, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Carrier furnace, pilot does not light, fans run
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Nov 28, 2009
Carrier infinity furnace 2010 has stuck inducer pressure switch, Can I manually bypass and heat the house until serviceman arrives tomorrow?
I wouldn't bypass any safeties when its part of the exhaust system of the furnace. That is the first safety that acts in the furnaces sequence of operation. The induced draft will initiate and that pressure switch will close, proving the IDM is working and flue is clear. It's primary purpose is to exhaust any fuel that may linger inside the heat exchanger and then to reject the post combustion process. Carbon monoxide becomes an issue. As far as the Infinity, these units will not start if safeties are bypassed. The unit checks all safeties/circuits for continuity, and if a switch is closed when its not supposed to be, it won't allow.
Mar 05, 2017 | Carrier Heating & Cooling
HK42FZ034 status code light blinks in pattern
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
Apr 13, 2014 | Carrier Furnace Control Board Bryant...
Led blinks three times and no ignition.
ignitor is bad or board not feeding it power or air switch is bad or draft motor not running fast enough
Nov 02, 2013 | Carrier Honeywell Gas Furnace Control...
FURNACE LITES UP RUNS FOR 2 MIN. SHUTS OFF GAS.PAYNE
Carrier had a recall years ago on the HK42fz004 & I believe the 008 models because of intermittent problems like yours. Sounds like you need a new board
Jan 02, 2013 | Carrier Furnace Control Circuit Board...
Wiring diagram for carrier HK42FZ011 circuit board
Wire for wire if you are a novice. The schematic should be on the blower door just in case you get lost. I myself have changed hundreds of them and just undo the wires since I know where they go.
Jul 17, 2012 | Carrier Furnace Control Circuit Board...
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
Carrier 90% *** furnace, fires up, runs until circulating fan runs for approximately 60 seconds, then the flame shuts down. The trouble code is 3-4 indicating a flame proving circuit problem. Three cycles...
I have had this problem many times. If changing the flame sensor and cleaning the front of the venturi tube did not help. Also check the ground wire that is attatched to the burner assembly. Also, I have found it necessary at times to replace the wire completely from the flame sensor to the ignition board (circuit board). if you have a multi meter that is capable of reading micro amps, put it in series with the flame sensor and you should see 3-5 micro amps dc. If this is not present, check and make sure that the flame is covering the sensor fully.
Apr 21, 2009 | Heating & Cooling
Heating & Cooling Logo
236 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
