Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Red convergence still won't move L or R
I switched the new ICs and now the same problem exists, the red will not move left to right, only up and down.
I am desperate for help at this point...
  • 7 more comments
  • thehumanlynx Apr 15, 2008
    842 looks smoky. I think that is the problem.
  • thehumanlynx Apr 17, 2008
    842 was the culprit. I switched it out and it is working now. The only current problem I have is that everytime I turn the tV back on after its off, the convergence is all screwy. After a minute of manual convergence it looks good again.
    Any idea why it would be doing that?
    thanks
    press muting once? or press and hold
    Hmm, I tried it both ways on the convergence screen and the main screen and it keeps messing up.. upon restart
    No I did not.
    Do i Need to unplug and push that button?
    ok. I will keep the TV on, push that button, set the convergence manually, hold down "muting" and it should save?
    I don't see a button. I guess I'll have to pull the board out to see it
    no button that I recognized? idk
    I hit reset on the convergence menu. That seemed to do it.
    Fixya! thanks for the help
  • JVC Master
  • 8,617 Answers
Check the following resistors. you need to lift one leg of each resistor out of circuit to check them. R803, 806, 805, 834, 837, 839, 840, 844, 842, 843, 847, 846 one or two of them may be open.
Posted on Apr 15, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Apr 17, 2008
    After setting the convergence you have to press the muting key on the remote to save the settings that stores the settings in the TVs processor
  • Sonny Berry
    Just hold it for a second that should store the settings
  • Sonny Berry
    did you press the service button on the convergence IC board before resetting the convergence after replacing the ics?
  • Sonny Berry
    No just remove the speaker grille the button is right next to the ICs just push it once then set your convergence and when finished try pressing the muting button, that should store the settings.
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
My magic focus won`t move my red lines left to right, it will move up and down.
Without knowing make and model of set. i would have to guess that on of your output resistors in your convergence curcit has failed. there is a possiblity that one of your stk amplifer ics is bad
Jan 11, 2009 | Televison & Video
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
Red is out of convergence
You can repair it yourself by replacing both STK392-110 Convergence ICs. You can get replacement ICs at the following link with free instalation instructions . Heres the link.
http://servicemanuals.vstore.ca/
Aug 08, 2008 | Toshiba 65HDX82 65" Rear Projection...
Hello Again
Its possible one of the resistors were weak from the other ICs. Which way does the red refuse to move as that can help you pin point which resistor you should check
Jun 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Ok, so I Replaced stk-392-110 (2) and......
Check the resistors in the red convergence circuit right next to the Ics you will need to lift one side of the resistor out of circuit to acurately check them but usually one or two resistors will be opened when the ICs go out
May 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
