Question about Motorola Mobility Moto Q
The space button on my motorola q is very stiff on one side of button
The space button is very stiff almost as if it is jammed on one side of the space button. Still works, however afraid it will eventually get stuck or wear out...only had a month
    Sergeant:
  • 260 Answers
I don't think this is a problem, but you may try blowing some compressed air into the keypad. Remember to hold the canister of compressed air back to the chemical that shoots the air does not get into your phone.
Posted on Jun 19, 2008
The receive indicator is permanently on, on the TLDR-T5 so the walkie talkies only work one way. How do we fix this?
Check the buttons on the radio. One may be "jammed" especially the MON button. It would indicate receive all the time. Check for dirt around the button and case, it can surprise you what little can jam a button. I clean around the buttons with cotton swabs and alcohol. Be careful and do not use sharp objects to move the buttons back and forth, side to side, up and down. I suggest your fingers, or a dull letter opener or screwdriver, but little force. If the MON or other button does not release, you may need to take the case apart.
http://www.motorolasolutions.com/content/dam/msi/docs/business/products/two-way_radios_-_unlicensed/_documents/tlkr-t_series/static_files/t5_manual_eu.pdf
Sep 03, 2016 | Motorola TLKR T5 Two Way Radio
The spacebar on my type writer is stiff. It doesn"t press.
It is probably jammed by something undernieth. You can try to take the screwdriver and carefully remove the spacebar button (just pull the button up, but please be carefull :) ) and then check is there something under that is jamming the space bar.
May 23, 2011 | Computers & Internet
Phone buttons won't work, locked up cannot dial out or accept incoming call
This might sound strange but have a play with the volume and camera buttons (the buttons either side of the screen). One of the most common causes of non-working keys on the V3 is a jammed volume/camera button.
May 27, 2010 | Motorola Mobility RAZR V3
NO I have the same problem as listed here "the canon pixma MP520. It says there's a paper jam but I can't clear it and the paper wonlt go through. I've got a horrible feeling something fell in and got...
You can try putting and index card or something stiff like that back thru the paper path to push back whatever is stuck. Look real close with your torch thru the spaces in the white guides that are over the long gray platen roller. Also the gray roller could have scratch marks in the area where the object is jammed. Be careful not to push back the sensor lever that is on the right side behind the white guides.
Feb 01, 2010 | Canon PIXMA MP520 InkJet Printer
How do i replace the presario v2000 battery? I cannot take the old battery out.
The cover may have been jammed if the laptop was dropped.
1. Use a stiff letter opener and run it along the edges of the battery cover.
2. Move the mechanical lock switch to open
3. Use the stiff letter opener to pry the battery out.
4. The goop you find is probably dried-up coffee, or some energy drink...
Sep 28, 2009 | HP Compaq Presario V2000 Notebook
How do you space between words on an older razor phone?
To put a space in between words in a text msg or text body, you hold down the *STAR button. The space key looks like this ( __ ) and it is on the *star key on the old Razer
Sep 02, 2009 | Motorola Mobility RAZR V3
Slim jim did not work in opening the veh.
take an old auto antenna or, a very stiff metal rod and, using a plastic blade (like a plaster knife) bend the glass on the driver's side door; at the top of the door; gently outward; place a rubber or, wood spacer (eraser, wedge etc) between the door frame and, the glass: you only need one inch space; use the rod to press /pull the button / lever on the passenger side
May 29, 2009 | 2001 Hyundai Elantra
I have a motorola tracfone w175g and wondering how to capitalize letters? do you have a detailed manual on the buttons?
Press "0" key.
A plus or minus sign will display in the text space.
The (upper case) "AB" or (lower case) "ab" on the top left-hand side of display will change to case you are seeking.
May 02, 2009 | Motorola Cell Phones
Leaves space while typing txt message
Perhaps that happens because u press the right side button of the d-pad after every letter u input.
Dec 12, 2008 | Motorola Mobility ROKR E8 Cellular Phone
I dropped and it came apart
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Jan 12, 2007 | Motorola Mobility H700 Wireless Headset
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
35 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
