Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome 1200 dvd player/recorder
Will not load dvds, either to play or record i have tried several of each. please help. Thanks
  • Anonymous Apr 15, 2008
  • Anonymous May 12, 2008
    i need manual so i can hook up to tv
  • 472 Answers
Chances are your laser needs to be either cleaned or aligned. If it's only cleaning then you will be best to do it correctly by removing the cover of the dvd player and properly cleaning the laser lens.
  1. Disconnect from power
  2. Leave the unit to sit for 20 minutes to allow the power stored in the unit to drain.
  3. Remove the top cover of the DVD player
  4. Remove the cover that contains the top spindle
  5. Using a NON ACETONE nail polish remover or good quality alcohol based cleaner, did the end of a cotton tip into the cleaner of choice.
  6. Do not put the whole thing in, just the very tip is fine.
  7. Using the tip and a gentle hand, clean the top of the laser lens. Do not push hard, just rub backwards and forwards, in circles etc, but NOT HARD.
  8. Use the other end of the cotton tip to wipe the lens again, just a quick wipe to help remove any excess fluid, or dirt that maybe there.
  9. Leave it open for about 5-10 minutes to ensure the laser lens is completely dry.
  10. Re-assemble the unit.
  11. Plug it in and away you go.
If this dosn't solve your problem, then you will need to have the laser realigned..that is a job for a tech and your local TV repair centre will be able to take care of it.
It's also possible that the laser unit is beyond repair, and then the laser assembly will need to be replaced.
Hope that helps.
Posted on Apr 15, 2008
Cyberhome DVR 1600 DVD
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyberhome ch-dvr 1500
try and reset the machine back to factory settings or update the BIOS through the Cyberhome Update site here:
hope this helps
Nov 20, 2008 | Cyberhome CH-DVR1500 DVD Recorder
Dvr 1200 will not play
After you have recorded you must "FINALIZE" the disk in order to play it in other DVD players or CPU. Press EDIT scroll down to Finalize Disc then OK
Nov 25, 2007 | Cyberhome DVD Recorder - DVR1600
Cyberhome 1200
I have a cyberhome 1600 dvd recorder and I need a code to program it to my bell remote but can not find any codes for the cybehome. can someone help with the codes
Nov 23, 2007 | Cyberhome DVR 1600 DVD Recorder
CyberHome DVD Recorder - DVR1600 says No disc when there is a disc
Hi! Pick a jhonson's bud -- dip it into the lens cleaner solution -- rub gently on the lens both clockwise and anticlockwsie -- leave it to dry -- cover up -- run the machine.. but be careful -- don't touch the lens with ur finger and dont try to rub roughly -- lens may go forever. still if the problem remains , replace the lens. chhoton
Aug 21, 2007 | Cyberhome DVD Recorder - DVR1600
Cyberhome dvr1600 problems
Try cleannng machine with dvd cleanner if u have staples surplus near u it only costs 10 can cn twice thiswoked for me had a same promblem.
Aug 10, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1200 acting up; won't format new blank dvds; says no disk,etc
Cyberhome has gone out of business in the US. My DVR 1200 stopped working but I was able to repair some capacitors on the power supply to get it going again. You can find more support information about the 1200 and 1600 on these websites: or and search for Cyberhome.
Jan 02, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome CH-DVD 300 DVD Player Logo
48 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
