Question about Dell UltraSharp 1703FP 17" Flat Panel LCD Monitor
Screeen comes on --then goes blank
I purchased a used Dell 1703FP because it was similar to a 1704 FTP I already own. The light powers the monitor on and the color bars appear for a split second...then it goes blank.
  • 472 Answers
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Posted on Apr 15, 2008
Dell? 1703 FPT. Where can I obtain a manual?
Actually there are not many options to contol manually a Dell monitor.. Here you have a setup manual
http://www.manualslib.com/manual/36463/Dell-Ultrasharp-1703fp.html
Found these specifications.
http://www.itema-pg.com/promo/2008/Mai2008/15-Philips/Specifications_%20Dell%201703FP%20Flat%20Panel%20Color%20Monitor%20User's%20Guide.pdf
Up to my knowledge, controls are mostly intuitive. Monitors have some buttons under lover right border, where you can manipulate some properties. Search for them.
Dell UltraSharp 1703FP Setup Manual
Manuals Dell US
Dell 1703FPT DVI LCD Monitor
Oct 08, 2015 | Computers & Internet
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Intermittent monitor blackout
if you check key board caps lock or num lock keys, also on aond off (LED in Caps and num lock)
you have check the video card , pls go to safe mode and test the problem
also need the check monitor with another pc
Sep 12, 2017 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Dell 1703FP monitor issue
reduce the hardware acceleration on it. I resolved it by reducing acceleration and changing my screen size. It works. I wanted higher resolution but it doesn't seem to be possible for some reason.
Good luck.
Mar 01, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 14, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Dell UltraSharp 1703FP 17" Flat Panel LCD Monitor Logo
378 people viewed this question
Alun Cox
