Question about Clarion VRX935VD Car DVD Player
Help with install on clarion vrx935vd
I need a diagram .which wire goes where to make it work right.please
need wiring diagram
  • coggie May 11, 2008
    the unit plays a dvd via the multi main wire component but the screen in the head unit itself wont come out and up .Is a wire not conected to the park/e-brake. so you cant watch a movie while driving ?
  • 51 Answers
Depends on the type of car you have and everything, I think you should take it to a professional.
Posted on Apr 16, 2008
Clarion vrx935vd how to hook it up. i have a black cord and i think its a adapter and i dont no where to find it or whats it called but i dont no how to find it or hook it up.
the adapter would be for a sirius satellite radio
here is the wiring diagram
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Sep 20, 2009 | Clarion VRX935VD Car DVD Player
My clarion vrx935vD doesn't come out.
simple thats because you must have forgot to plug the small adapter in the back of the deck that has a yellow and black wire coming from it. if you have then one of those two wires are not hooked up to the right place. and if that fails then either u have a bad connection somewhere in ur car wire or in the inside of ur deck. i had the same problem when i hooked up mine i just forgot to hook up that adapter because its really small
Oct 06, 2008 | Clarion VRX935VD Car DVD Player
Wiering
For a Clarion VRX935VD, installation and wiring information may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Clarion VRX935VD Car DVD Player
The green would have to be connected to the handbrake indicator switch. Additionally, Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Jun 13, 2008 | Clarion VRX935VD Car DVD Player
Robert
The best solution is to google Clarion and serial # to deck, also include manual. EXAMPLE: Clarion VRX935VD Manual....And in that manual there will be a wire connection page. It will show you the best possible way to install the deck into your car.
Jun 12, 2008 | Clarion VRX935VD Car DVD Player
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
I love Clarion
1st RED is + direct to battery
Yellow is + pwr to ignition so when you turn the car off the radio can still say on if you choose
black is - and ground
these are importantant first. once you have pwr you can easily work out which of the 8 other wires are pairs 2 frnt spkrs and 2 back speakers if theres 2 extra plugs for the amp or woofer(if screws run a nice thick speaker wire. But with Clarion I dont beleive you need an amp or woofer thats how good they are just have kickass speakers frnt an back
you should be able 2 find the pwr cables from the existin radio if not the yellow wire leads to the igniton and you can run a red wire staight to the battery and screw the black wire to the metal chasis(oh the blue wire is for a pwr antenna or aux and is not needed unless youve got a pwr antenna.
your speaker color code will be like eg.grey and grey with white stripe,will be one pair green another pair ,but the 4 spker pairs are skinner than th pwr cables
Spkrs have a + and - too the difference is you cant blow the spkr by trial and error its just if its wrong it will sound muffled so try both ways then youll know whats best. pwr must be correct make sure red on red and blacks on black then press on then play with your speakers then find the yellow cable that runs to the ignition then to the radio so when you turn the ign the radio comes on and when you turn the motor off you can turn the radio on cos youve also got a direct to battery connection.
Man you are gonna love your sound system
Im happy for you
Clapster
Feb 24, 2008 | Clarion VRX935VD Car DVD Player
Clarion VRX935VD
I have had a 935VD(Clarion) for about 6 months now, and i decided to add headrest monitors. After i did the physical installation, i moved onto the wiring (obviously). The way i decided to hook the power up was to tap into the accessory power feeding the brain of my 935VD - that may have been a bad idea, but whatever, i did it. Anyway, when i was installing it i accidently grounded the accessory wire and blew the accessory fuse under the hood. Thats fine, i just finished wiring it up and replaced the fuse after completion. The problem is that when i turn the car on now, the deck will not go on. On the deck - in its closed position - all the buttons light up, but the front display does not go on, and it acts like it is off (the eject button works but it will not take a CD in). I was wondering if you guys have any suggestions. I would apprecaite it. Right now im nervous that i fried the brain, but i where it was grounded was between the battery and the brain, so it should not have done n e thing to it... who knows...
Jan 08, 2008 | Clarion VRX935VD Car DVD Player
Clarion VRX935VD Car DVD Player Logo
501 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
