Question about Bosch HBN 442 / HBN446 Electric Single Oven
Bosch oven HBT346 - how do I reset the clock?
I have a Bosch oven HBT346, and I'm unsure how to reset the clock to show the correct time. Can you help?
Thanks very much.
Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
Posted on Jun 15, 2010
  • bigbennie Oct 31, 2010
    Press the "clock" button twice ...then set time with the or - buttons....
Bosch single oven has clock function but when I reset it goes to military time
Never heard of Military Time unless you mean 24hour clock in which when the power is interrupted or the clock is reset, that is the default setting.
Jun 18, 2017 | Bosch Ovens
We clean are double wall oven and I can,t reset the clock.
Hi williamk77,
Your post "reset the clock" may refer to three (3) clocks in your Dacor ECS230. The first is the "Setting the Time of Day" which could be performed by pressing on the "CLOCK" touchpad. The time of day will falsh. "AM" or "PM" will be displayed and "TIME" will flash in the display. Thereafter, press the touchpad "+" or "-" until the correct time of the day is displayed and release touchpad.
The second is the "Using the Minute Timer" which is better explained at the user's manual page 6. Below is a snapshot of that part of that page.09d8cbe.jpg
and the third is "Timed/Delayed Timed Cooking" likewise better explained at the user's manual (p.9). Should the manual be not readily available, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 27, 2008 | Dacor ECS230 Epicure Electric Double Oven
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
Can not set clock
For the NW09DO, press the outer two buttons ("-" and "+") together and hold for three or four seconds. Then press "+" to advance the clock/time and "-" to go back.
When the correct time is showing, leave the buttons alone for four or five seconds.
Feb 19, 2009 | New World E70DOa Electric Double Oven
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    HOW TO GET CLOCK TO DISPLAY
    1. check the power suply, such as bttery etc.
    2. 4 years maybe long enough to replace another one.
    Jul 06, 2008 | Bosch HBN 755 Stainless Steel Electric...
    Bosch HBN 442 / HBN446 Electric Single Oven Logo
    3,466 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
