Question about Brother SE-270D Computerized Sewing Machine
SINGER SEWING MACHINE MODEL 3140 MERRITT
I CAN'T GET THE MACHINE TO OPERATE THE THREAD KEEPS BREAKING OR THE BOBIN THREAD NOT ATTACHING AND SEWING
  • 323 Answers
SOURCE: how do you thread a
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Jul 14, 2008
SOURCE: I have a singer merritt 9612 but it doesn´t
The problem is solved, it was the tension in the sewing machine. Now I know it must be always en 4. Thank you and God bless you.
Posted on Jul 23, 2009
SOURCE: how do you thread the bobbin on the singer merritt 3140
Go www.singer.com they have the manual for this machine available for download on their machine.
Posted on Sep 22, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
  • 980 Answers
SOURCE: My Singer 507 sewing machine keeps on jamming up,
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Posted on Apr 09, 2010
The tension knob will not turn below four. The thread keeps breaking.
check that the thread is between the plates and not behind them
thread breaking can be from wrong size needle eye, poor quality thread , old thread and needle/ eye timing
Dec 11, 2015 | Singer Merritt 8734
How to thread Singer merritt#9608? Probledm with birdnesting
what size bobbin and do you have pictures to show how to thread 9608 singer machine
Mar 10, 2012 | Singer Sewing Machines
I need the correct setting for my singer merritt 3140...I keep getting bundling thread from the bobbin
Always remember that it is the opposite of what you think, it is not the bobbin thread - it is your upper threading, you don't have it threaded right. Go to brother.com and download the manual for free and then enlarge the threading page. I am sure that you will be amazed, because I sure was. Good luck
Jul 27, 2010 | Brother SE-270D Computerized Sewing...
Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
Jun 18, 2009 | Janome 6019QC Mechanical Sewing Machine
How do you thread the bobbin on the singer merritt 3140
Mar 08, 2009 | Brother SE-270D Computerized Sewing...
Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Oct 21, 2008 | Singer 7462 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
477 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
