Question about HP LaserJet 3050 All-In-One Printer
All in one printer
I installed a new print cartridge. On the window screen, it states; No Print Cartridge. I have turned it for a day. I made sure the cartridge is inserted correctly, but the printer is not recognizing the cartridge being installed.
Did you remove the pull strip from the new cartridge?
Posted on Apr 16, 2008
HP6988 printer skips lines and only prints bottom half of black lines. Installed new black cartridge, printed test page. Still no change.
Most deskjets include a maintenance section. Open this printer in PRINTERS on Control Panel (assuming Windows). right click on the printer and select properties. You will have to look for the maintenance section. There you should find an option to "clean heads". You may need to do this several times if never done before. After each cleaning, print a test pattern. Hope this helps.
Mar 31, 2011 | HP DeskJet 6988 Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Installation of cartridges correctly
Follow these steps to install the printer cartridge :
•1
Make sure the HP printer is turned on. Open the print carriage access door. Wait for the carriage to stop moving.
•2
Remove the old cartridge from the print carriage.
•3
Remove the new print cartridge from its packaging. Being careful to touch only the black plastic, gently remove the plastic tape by using the pull tabs. Make sure you've removed all of the tape.
•4
Slide the new print cartridge into the empty slot in the print carriage. Push the print cartridge forward until it clicks into place. Press down on the latch until it is securely closed.
•5
Close the print-carriage access door. Print a test page to make sure your new cartridge is properly aligned.
Oct 20, 2010 | HP Photosmart C4150 All-In-One InkJet...
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How do I align ink jets?
      3. Click OK.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
HP LaserJet 3050 All-In-One Printer Logo
62 people viewed this question
Ben Johnson
